 Pinto Turbo Conversion - Howto
Lister Mister
corrode
davus
S12Cat
kyllo
Johnny T.
Jpereira
Posmo
haggis
Zozz
Thierry
Boby
Tim
M-H
smurf
martini22
PePe
Tehnic
Jonas O
Luyo
YSM
ESKIN8R
InFlammen
nitrousnutter
Alcazar
Kovu
Jankaou
37 posters
Pinto Turbo Conversion - Howto - Sida 5 Empty
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimesön 29 mar 2009, 22:04
Haven´t had any problems with it, perhaps your turbo is in bad shape.
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
Kör : Sierra 2.0 DOHC
Registration date : 09-05-19
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetis 19 maj 2009, 22:47
Hy, I'm from Latvia.
This is my sierra Pinto Turbo Conversion - Howto - Sida 5 Bildess005
This summer I'm going to replace te DOHC engine with pinto and try to add turbo to it.
I have got some questions about your turbo conversion.
1. Where can I mount the oil pick up for the turbo?
2. And where can I buy the splitter for the fuel lines for the extra injectors.
Thanks for your help, hope my T25 will be fine for this engine.
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 maj 2009, 16:43
Figured out all my questions my self.
Jus one major question: should I get the Pinto engine with or without Lambda and CAT?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 maj 2009, 18:25
Cat has less compression so it´s a better choice if you are planing to go with stock engine
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 maj 2009, 23:26
Im planning to run the presshurebutton operated fuel system. Won't there be any problems with an engine which has lambda?
Yes, I will be running the engine competely stock.
Thanks for the quick reply.
Thierry
Thierry
Antal inlägg : 83
Namn : Thierry
Från : FRANCE
Kör : hondschoote
Registration date : 09-11-22
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimefre 27 nov 2009, 22:46
Hello, my name's Thierry , i'm from france.
Tomorrow i'm going to buy a 1986 Sierra 2L pinto EFI.
I want to convert it, but in your tutorial some fotos are missing.
I don't understand every thing. Thx for your help
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimefre 27 nov 2009, 23:02
Ouch, i must check if i have the right pics on my computer.
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimesön 06 dec 2009, 22:17
I have searched for the pics but don´t have them om my computer anymore
Thierry
Thierry
Antal inlägg : 83
Namn : Thierry
Från : FRANCE
Kör : hondschoote
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimelör 16 jan 2010, 21:13
Erf ! Sad
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
Kör : Scorpio 2.9 12V Ghia, Sierra pinto EFI,
Registration date : 08-09-30
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimeons 20 jan 2010, 00:02
Hi!
Which size of a turbo fits to pinto if I want a low cost k-jet cold start injectors whith pressure switch solution with about 0,6-0,7 bar of boost? The engine is stock also. Now I found a same as this one:
http://www.turbodaddy.net/garrett/pdfs/garrett-TA0304-465384-5.pdf
But I think it will be too small because this is the stock turbo of VW golfII/jetta 1.6GTD
http://www.sierracorner.net/
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimeons 20 jan 2010, 06:53
A turbo from a car with similar engine size would do great
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimesön 24 jan 2010, 16:36
Are you use oil cooler on these low cost pinto turbos?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimesön 24 jan 2010, 16:37
Actually not, but it´s a god idea to mount one
haggis
Antal inlägg : 4
Namn : craig corson
Från : scottish!
Kör : eh?
Registration date : 10-01-28
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 03:56
Hey Mikael
your probably sick of people asking silly questions but what is this
Pinto Turbo Conversion - Howto - Sida 5 2mo4j2o.th
I have been buying the cold start injectors off ebay but dont know what to search for with this.
ive tried Fuel rail adapter, fuel splitter, nos splitter, gas splitter, nos adapter.
the list will go on and on if you dont tell me!!
also, what kind of pressure switch am i looking for.
i would have imagined something that turns on around 5 psi.
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 06:50
It´s bought from store that sales spares for pnenumatic machines
I don´t have a name on the pressuare swicth but the pnenumatic store can find you one if it well sorted
haggis
Antal inlägg : 4
Namn : craig corson
Från : scottish!
Kör : eh?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 11:30
ahh found it, its for air brushing and is called an air brush splitter or manifold.
thanks
haggis
Antal inlägg : 4
Namn : craig corson
Från : scottish!
Kör : eh?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 18:16
would a turbo from a nissan pulsar run my pinto ok
think its a T28
just came into the scrapyard near me!
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 18:23
it will work
Thierry
Thierry
Antal inlägg : 83
Namn : Thierry
Från : FRANCE
Kör : hondschoote
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 19:45
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 20:15
Nice Manifold there.
Thierry
Thierry
Antal inlägg : 83
Namn : Thierry
Från : FRANCE
Kör : hondschoote
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 20:16
Have you seen the links to your movies ? You're famous ! Smile
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimetor 28 jan 2010, 20:21
Yes a saw that, no big deal really Smile. There were just one there thats on my car
haggis
Antal inlägg : 4
Namn : craig corson
Från : scottish!
Kör : eh?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimeons 03 feb 2010, 15:31
started on the efi inlet manifold today
i wanted to have extra space on the flat areas of the manifold so i could mount extra injectors at a later date.
so i roughly positioned the current injectors 8 inches from the head.
i made a template out of a plastic card and drilled the holes. 4,5mm for the screws and 8mm for the injector.
i then filed the area round the big hole flat for a decent seal.
i was going to use o-rings but went for chemical metal to seal round the holes.
the injectors were a tight fit so a tap in with a glasgow screwdriver and they were home.
i finally fastened them using 5mm stainless self tappers and hey presto, an 8 injector set up!
still got to find an adjustable pressure switch to turn them on.
does anybody know the banjo size of a k-jet cold start injector for the plumbing?
Pinto Turbo Conversion - Howto - Sida 5 Dsc00296nm.thPinto Turbo Conversion - Howto - Sida 5 Dsc00299h.th
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimelör 06 feb 2010, 21:49
When I use standard injectors whith Kjet cold start injectors do I need to adjust harder the MAF spring? Or the only reason if I put in bigger injectors to standard? And what size do you suggest? Around 300cc enough?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 5 Icon_minitimelör 06 feb 2010, 22:19
You don´t need to adjust the MAF with extra injectors.
If you don´t want extra fuelinjectors you can skip it and exchange the standard injectors for example 300. But it can be tricky to get it to work fine on lower rpm
Sida 5 av 7Gå till sida : Föregående  1, 2, 3, 4, 5, 6, 7  Nästa
» About the Pinto turbo conversion
» Wich turbo to choose for PINTO conversion
» [ FRANCE ] Ford Taunus 1974 2.0 pinto turbo conversion
» turbo technics pinto turbo manifold
» Pinto Turbo - Gearboxes
