 Pinto Turbo Conversion - Howto
InFlammen
Antal inlägg : 14
Från : Spain
Kör : Sierra RS Cosworth, Sierra 2.0is (to be turbo'd)
Registration date : 07-05-28
Pinto Turbo Conversion - Howto - Sida 3 Empty
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimetis 23 okt 2007, 18:41
I don´t think we have anyone in here that knows about megasuirt. I don´t like myself, it´s to much reading to make i work. And the program looks to be designen by a 10 year old child.
http://skogenracing.editboard.com/search.forum?search_keywords=megasquirt&show_results=topics
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
Registration date : 07-11-11
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 03:39
Hi All,
I'm also a hungarian Sierra fan and I would need some information as well from you, you Pinto experts Smile
So I have a 24V Cosworth in my Sierra, it works fine but I need more power...
Also I would like to reduce the car's weight, so mainly that is the reason why I want to swap the 24V and and apply a 2 litres pinto engine with turbo (the 2.0 Cosworth is expensive).
I need min 300 hp, but if possible about 400.
My question is how can I retrieve this power from a pinto with turbo, what are the details, probably you have engine in this range...
Thanks in advance,
Luyo
Jonas O
Antal inlägg : 51
Namn : Jonas
Från : Kalmar
Kör : Saab / Opel
Registration date : 07-08-18
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 11:58
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 12:29
Oh it's very simple, since I have Ford, I would like to run Ford engine.
I don't want to change engine from an other brand...
But it looks fine Smile
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 16:22
That Saab/Ford don´t have 400hp, actually my old sierra where a couple of seconds faster 0-200km/h
Luyo:
Keep the cosworth V6 and mount a turbo on it instead. 1bar will give you 400hp with no trouble at all.
300hp pinto will demand a bit more work.
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 18:15
Luyo:
Thanks Mikael!
So you say that it will be much cheaper if I keep the 24V and mount turbo on it...
In this case do you now any specifications about this project?
So I think I should use 2 turbos, but what kind of turbos? Should I use forged pistons or the stock Mahles will be enough? You say 1 bar, it sounds good but what about compression, should I change the gasket to modify the compression, or some machining on the pistons do more? Or the stock engine will sustain the 1 bar?
So it raises lots of questions and probably I can have them answered also in Hungary but it would be better if you could give me advices about it, as I think hungarian mechanics don't have experience on turbo 24V engines, maybe you do.
I appraciate any help Rolling Eyes
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 18:24
Luyo:
Thanks Mikael!
I would recomend one turbo, its cheeper and much cooler with one large turbo than two small ones.
A friend of mine used stock parts and compression but he used a mixture och Ethanol(85%) and gasoline(15%)to get around detonations. To run on gasoline you should lower the compression by using a coppergasket or machining the pistons
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 23:34
Okay Mikael thanks again! Smile
So let me summarize and ask some more questions:
-one big turbo either side is stronger than 2 little? (what about the other side, simple exhaust manifold?)
-which type of turbo do you suggest?
- coppergasket or machined pistons to lower the compression (I think, to get a gasket is much easier but how can I calculate the thickness of the gasket? Is there any program to calculate it? The stock compression ratio of the 24V is 9.7:1 Which compression should I use?
-should I change anything on the ignition?
-will the stock EEC IV computer work with this tuning? (air mass meter, etc...)
- I have an old 2.8 V6 fuel pump, will it carry enough fuel for the injectors?
- are the standard injectors are enough?
-of course I will swap the mt75 to t5 with the clutch system...
Thanks again in advance!
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 23:38
one mainfold to one turbo, you have to collect them togehter..
injectors ill think u have to get some bigger ones.. u can calculate that..
the other questions Mikael have to answer..
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimesön 11 nov 2007, 23:53
Yes I understand, but you know as it's a V6 engine I have 3 exhaust ports each side. I can collect them to one mounting to the turbo each side. But Mikael said that I should use only 1 turbo, so that would be one side, but what about the other side? That would have been my exact question Wink
Sorry, I'm not a technician...
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 12 nov 2007, 00:19
u have to collect all 6 exhaust ports to the turbo on 1 side..
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 12 nov 2007, 06:57
Holset HX40 or att Garret GT40 would be perfekt for you. Forget all Hybridsturbos (T4/T3) and other small turbos. On that engine you will need a big one. Around 50-60mm on the inlet and 55-65 on the outlet will do just fine.
3mm gasket will do the trick. I haven´t tested cooper gaskets but know that it works for others
For the fuel i would rekomend a aftermarket fuel/ignition system. Standard system will not work so good.
Haltech, Autronic, Vems, Megasquirt and so on. It's expensiv but you will not regret it. Bigger injectors is required. 400cc or bigger to support 400hp, and you will also need two 2.8 fuelpumps.
It´s not cheap to build a engine with twice the power. You could try using extra injectors as i have described in this thread.
And of course you will need to connect all six exhaust to the turbos.
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimetis 13 nov 2007, 00:08
Mikael, xcOOb, thanks again for your help!
Now according to your instructions I 'm starting to understand this Very Happy
I'll try to have a look around about the prices and calculate how much does it cost, also discuss with a mechanic.
First I should buy the turbo, injectors, computer and the other parts then fabricate what I can't purchase.
Just one question Mikael, what did you mean on "Around 50-60mm on the inlet and 55-65 on the outlet will do just fine." ?
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimetis 13 nov 2007, 08:48
It´s the size of the compressor and exhaust wheel on the turbo
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimefre 16 nov 2007, 00:12
Hey Mikael, have you heard something about the 4.0 V6 24V project when the engine block is an Explorer, but the cylinder heads are cosworth 24V? It would be good to mount a turbo on this engine which is 280 ps when it's naturally aspirated. With 1 bar maybe it could produce about 500 ps Smile
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimefre 16 nov 2007, 08:32
Luyo
Luyo
Antal inlägg : 16
Namn : Luyo
Från : Hungary
Kör : Volvo 242 T6
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimefre 16 nov 2007, 18:13
It's not bad, but I think for RWD the 400 ps will be absolutely enough...
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
Registration date : 07-12-17
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 12:39
Hey Can somebody tell me how much Euros it will cost to tune up an pinto engine like the silver one with holset turbo? Amazing power what I saw in videos Very Happy
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 13:58
Mikael can answer that, look in later and u will sure have an answer on that..
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 16:45
It's always difficult to estimate cost. Here in sweden 2000 euro will do the trick
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 19:23
all same parts as on this silver sierra and so cheap`? And one thought of mine is that will somebody do it all for me in sweden if i take my sierra pinto there and pay somebody 2000-3000euros ?Very Happy
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 19:33
it built by Mikael him self not by any mechanic/store or so, then it will cost more..
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimemån 17 dec 2007, 19:42
Exactly i didn´t count the hours behind .
PePe
Antal inlägg : 8
Namn : Simo
Kör : Ford Sierra
Registration date : 08-09-26
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimelör 27 sep 2008, 00:06
Hello from Finland!
Great site you have here and I like your videos too.
But the main reason why I'm posting is that I'm planning on doing a turbo conversion for my Sierra.
That tutorial is great and just something what I have been looking for my budget. But the wiring diagram for extra injectors have gone I see, would it be possible to someone to upload it again? Could be very helpful.
Also how about the ignition timing? It isn't really adjustable in the EEC-IV, so I'm afraid of getting problems with knocking, original timing can be a little too early when there is boost.
In original iS Sierras there is this little 3-pin connector lying under the ignition coil and when you ground those wires you can get the ignition timing modified 2, 4, or 6 degrees later. Have you been using this method or something else, or have it even been required to get the engine run properly?
Thanks
InläggRubrik: Sv: Pinto Turbo Conversion - Howto   Pinto Turbo Conversion - Howto - Sida 3 Icon_minitimetor 02 okt 2008, 19:46
PePe skrev:
Hello from Finland!
Thanks
Pinto Turbo Conversion - Howto - Sida 3 Extrasprut_5
To the left is the pressure switch and to the right is the injector.
Most of all here dont do anything to the ignition timing whit orginal EEC-IV managment.
Sida 3 av 7Gå till sida : Föregående  1, 2, 3, 4, 5, 6, 7  Nästa
