| Pinto Turbo Conversion - Howto | |
+33Lister Mister bosse corrode davus Fiechen S12Cat kyllo Johnny T. Jpereira Posmo haggis Zozz Thierry Boby Tim M-H smurf martini22 PePe Tehnic Jonas O Luyo YSM ESKIN8R InFlammen nitrousnutter Alcazar Kovu Mikael Henrik Öbbe JBlom Jankaou 37 posters |
| Rubrik: Sv: Pinto Turbo Conversion - Howto tor 07 jun 2007, 09:28 | |
| Cosworth uses low impedance injectors. That can be a problem with Megasquirt, its not designed för low impedance så there are two options. Mount resistors in serie with each injector or get hold of high impedance injectors
For 240hp you need 350-400 cc/min I´m not sure what the colors on the cosworth injectors stand for. | |
ESKIN8R Skogenracing Small
Antal inlägg : 4 Från : New Zealand Registration date : 07-06-16
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 16 jun 2007, 08:42 | |
| Hello all, my name is Jason, I live in New Zealand Im going to be buidling a turbo pinto engine Using a suck though carb setup Has anyone done this sorta thing before? Here is my exhaust manifold Inlet manifold Engine ( 205 block) | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 16 jun 2007, 09:32 | |
| Yes i have tested that and it worked fairly well Sadly it´s not possible to use a intercooler, i guess it will be a problem with detonations above 0.5bar. If you want to use more boost you will need some kind of waterinjection | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 05:30 | |
| Hello again, can you give me any more info on what to do? What size turbo Whats the best way to lower compression Whats the best type of carb to use
Thanks | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 16:56 | |
| - ESKIN8R skrev:
- Hello again, can you give me any more info on what to do?
Thanks You need a turbo with carbon seal. Not easy to get hold on, some turbos can be rebuild but elsewere you need to find a turbo that whas fittet to a car with suck through. Look for pistons from a cosworth, with orginal rods you get compression around 7,5-1 with cosworthrods somewere around 8,6-1. I recommend a singel weber DCOE 40 or 45 | |
InFlammen Skogenracing Small
Antal inlägg : 14 Age : 45 Namn : David Från : Spain Kör : Sierra RS Cosworth, Sierra 2.0is (to be turbo'd) Registration date : 07-05-28
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 17:50 | |
| And what about the camshasft? I would like to use a specific cam for Pinto Turbo engines, but I have only found two sites that build it, and any of them reply my messages. One of them is ColtecRacing http://www.coltecracing.com/camshafts.html#pintoCould anybody help me to find a good cam?? | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 17:59 | |
| - InFlammen skrev:
- And what about the camshasft? I would like to use a specific cam for Pinto Turbo engines, but I have only found two sites that build it, and any of them reply my messages. One of them is ColtecRacing http://www.coltecracing.com/camshafts.html#pinto
Could anybody help me to find a good cam?? Why would you want a turbocam? It´s for silly people who want a boring engine. A ordinary camshaft for tuned engines without turbo works fine on a turbo engine. So buy one thats for street use (often called "fast road"). | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 19:12 | |
| Mmmm... Well, I don't know, I thoght that a specificic cam could be better. Whar is the difference in final result? Why do you say "boring engine"?
What about this one? Description: KENT CAMS FAST ROAD CAMSHAFT: SOHC PINTO INJECTION
Other Info: 1000-6250rpm .499" LIFT 263deg TIMING 110deg .008"/.010" CLEARANCE | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 17 jun 2007, 19:39 | |
| - InFlammen skrev:
- Mmmm... Well, I don't know, I thoght that a specificic cam could be better. Whar is the difference in final result? Why do you say "boring engine"?
Other Info: 1000-6250rpm .499" LIFT 263deg TIMING 110deg .008"/.010" CLEARANCE The difference betwen a turbocam and a ordinary is the overlapp, a turbocam have less overlapp, the meaning with this is to have boost earlier. But will result in a engine that lose some att higher rpm Here in sweden we prefer to build a powerfull naturally aspirated engine and just lower the compression. Look at my simply but not entirely correct calculation 100hk before, 1bar of boost = 200hk 120hk before, 1bar of boost = 240hk 120hk before, 0.7bar of boost = 200hk The camshaft you ask about feels a bit close to orginal. around 280 deg and 11-12mm lift will get a nicer engine | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto mån 18 jun 2007, 10:15 | |
| Will detonation still occur if I lower the compression ratio and Up the boost? KENT CAMS FAST ROAD CAMSHAFT: SOHC PINTO (CARB) 2500-7000rpm .442" LIFT 285/280deg TIMING 108deg .010"/.012" CLEARANCE Would that be a suitable camshaft to use ? | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto mån 18 jun 2007, 12:41 | |
| - ESKIN8R skrev:
- Will detonation still occur if I lower the compression ratio and Up the boost?
KENT CAMS FAST ROAD CAMSHAFT: SOHC PINTO (CARB) 2500-7000rpm .442" LIFT 285/280deg TIMING 108deg .010"/.012" CLEARANCE Would that be a suitable camshaft to use ? Lower the compression is a way to avoid detonation. But to low compression will make the engine weak at low rpm. Fuel with higher octane is another I suggest you mount a water injection system on a suction turbo system. Infact thats even better than having a intercooler. The camshaft you listed should work just fine | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto tis 19 jun 2007, 07:32 | |
| Hi again Thanks for all your replys I have never heard of or seen water injection Can you tell me more about it? Thanks | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto tis 19 jun 2007, 18:49 | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto fre 06 jul 2007, 23:28 | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 07 jul 2007, 00:30 | |
| Just take one. Its better than orginal so i think it will work fine | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 07 jul 2007, 12:03 | |
| Ok. I have a lot more questions... How about gaskets? Could I use Cosworth YB gaskets, or better performance pinto gaskets? And the cooling system?? | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 07 jul 2007, 23:13 | |
| Yes you can. I don´t know if there is any better gaskets for pinto, but cosworthgasket works
We use standard cooling system | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto lör 07 jul 2007, 23:44 | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 08 jul 2007, 00:43 | |
| Where could I fit a Cosworth 4x4 intercooler?? | |
YSM Skogenracing Small
Antal inlägg : 6 Namn : yam Från : 123 Kör : 1234 Registration date : 07-10-15
| Rubrik: Sv: Pinto Turbo Conversion - Howto mån 15 okt 2007, 22:08 | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto mån 15 okt 2007, 22:16 | |
| Looks like an Solex. Could it be an Soles 32dis designed for boost? | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto mån 15 okt 2007, 23:33 | |
| Yes it is. From a renault GT 5 turbo. As well as the turbo - GT25. We dont know how it will perform, so the whole project is in jeopardi at the moment , but i was hired to make the parts fit, not my problem if it wont start because of this setup. We purchase some diffrent sizes of jets for him from a Friend who owns a GT5, to make the tuninig as accurate as possible. i will post more pics when we will have some more progress. We are also planing to lock the DIF',lower the car and do some reinforcing on the old chasis...
Yam | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto ons 17 okt 2007, 23:41 | |
| Sorry for not posting the pics. It was raining yesterday and today so....no progress so far.
Yam | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 21 okt 2007, 01:38 | |
| Could somebody write a little guide to fit a Megasquirt manage system on a Pinto Turbo Engine? Like the firs post about the engine and the fifth injector | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto sön 21 okt 2007, 10:28 | |
| I don´t think we have anyone in here that knows about megasuirt. I don´t like myself, it´s to much reading to make i work. And the program looks to be designen by a 10 year old child. | |
| Rubrik: Sv: Pinto Turbo Conversion - Howto | |
