| Ford Sierra Pinto 2.0 T - Poland | |
+12janka26 combatkit xr4si Hedin_ Rekord E2 Turbo Boby Streetlover Golden Boy Kverna Öbbe Mikael Kriss Poland 16 posters |
Kriss Poland Skogenracing Small
Antal inlägg : 35 Age : 39 Namn : Krzysiek Från : Poland Kör : Ford Sierra Registration date : 08-12-09
| Rubrik: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 13:03 | |
Senast ändrad av Kriss Poland den mån 06 apr 2009, 19:50, ändrad totalt 1 gång | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 16:42 | |
| The pistons should work with just 0.75bar. I usually recomend 1bar as maximum on a stock engine. nice car by the way! | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 20:28 | |
| If I understand the serial pistons resist to 1bar I know that 0.7 is not much, but still break pistons ... Perhaps through an earlier knock combustion (detonation burning) ? After this I do not have additional controls for ignition and fuel. The engine control computer from Sierra 2.0 IS. MAF adapted so as to be worth AFR 12-12,5-13. EGT does not exceed 900 degrees. | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 20:31 | |
| car looks nice.. good luck with the project.. | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 20:35 | |
| Yes they manage 1bar if you have good AFR readings. I usually want 12.0-12.5. Often it´s needed to adjust the ignition somewhat, just turn the distribuator a little bit if you hear detonations | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 21:54 | |
- Yes they manage 1bar if you have good AFR readings. I usually want 12.0-12.5. Often it´s needed to adjust the ignition somewhat, just turn the distribuator a little bit if you hear detonations
I did do this, but I had mounted manual boost control to raise the charge but then at 3000RPM at third gear was already 0.6 bar and detonation burning ... I resigned from MBC and I set charger only with westgate. Where do you buy the Cosworth piston rings? | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 06 apr 2009, 22:03 | |
| I bought mine from a cosworth dealer here in sweden. But you can shop a set of rings from www.burtonpower.co.uk | |
Kverna Skogenracing Large
Antal inlägg : 122 Age : 36 Namn : Anders Från : Norge Kör : Ford Sierra 2.0 Turbo 3dørs Registration date : 09-01-21
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tis 07 apr 2009, 08:38 | |
| A guy here in Norway runs 2bars on stock internals. But the "safelimit" says to be around 0.7bars | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tis 07 apr 2009, 10:25 | |
| - Anders Kverneng skrev:
- A guy here in Norway runs 2bars on stock internals. But the "safelimit" says to be around 0.7bars
2bar for serial pistons? Wow ... I think about 1bar charger By the way, You heard about ECU MASTER (piggy back)? Because I`d like to electronically controlled ignition and fuel... and I don`t know how...
Senast ändrad av Kriss Poland den tis 07 apr 2009, 16:17, ändrad totalt 1 gång | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tis 07 apr 2009, 15:23 | |
| nice car man!
keep up! /Jonny | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tis 07 apr 2009, 17:22 | |
By the way, You heard about ECU MASTER (piggy back)? Because I`d like to electronically controlled ignition and fuel... and I don`t know how... Yes 2bars on stock engine. He dyno'ed 386hp on the wheels on 1.8 if I don't remember wrong Here's the project log, it's in norwegian but many pictures: http://www.fmcn.no/forum/index.php?showtopic=45978 | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland ons 08 apr 2009, 08:13 | |
Here's the project log, it's in norwegian but many pictures: http://www.fmcn.no/forum/index.php?showtopic=45978 I log on Turbonetics is a profesjonal turbo, very nice! I forgot about the brakes Front Brake Discs from Scorpio Cosworth 278mm Zimmermann Sport and brake terminals from Scorpio Cosworth Rear brakes is oryginal from Sierra with ABS + elektric braking pump. I add the computer with the installation to have the complete ABS
Senast ändrad av Kriss Poland den tor 09 apr 2009, 00:02, ändrad totalt 2 gånger | |
Streetlover Skogenracing Sponsor
Antal inlägg : 590 Age : 35 Namn : Robin Från : Karlsborg Kör : Opel Ascona C -87 & Ford Taunus 20m -65 Registration date : 08-05-25
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland ons 08 apr 2009, 23:02 | |
| hey man! I just love your car, it's beautiful! but I wonder about one thing.. Where did you bought the front headlights that you have on your car? sorry about my english but I hope you understans what I mean keep it up! //Streetlover | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tor 09 apr 2009, 15:25 | |
| okay, then I understand. thanks for you answer. hmm.. maby I will do that with my headlights someday It's a beautiful Sierra you have anyway | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tor 09 apr 2009, 15:37 | |
Boby Skogenracing Small
Antal inlägg : 15 Age : 33 Namn : Toms Från : Klame Kör : Sierra 2.0 DOHC Registration date : 09-05-19
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland ons 03 jun 2009, 14:26 | |
| Nice sierra. How did you modify the MAF sensor? | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland fre 12 jun 2009, 11:01 | |
| Hm... I changed tension spring on MAF (AFR setting), that`s all | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland ons 17 jun 2009, 12:30 | |
| Did you use softer or harder spring? Thanks. | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland mån 29 jun 2009, 14:48 | |
| beautiful look | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tor 09 jul 2009, 00:06 | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland tor 09 jul 2009, 11:53 | |
- ........(made by me).
I put in the original lights lenses bi-xenon from Passat B6 + xenon Hella with light bulbs Philips 4300K and polish lampshade (glass) - incredible effect!
How did you do the polish of the lampshade?? Glass is really hard... (tried myself but didn´t success..) | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland fre 31 jul 2009, 21:01 | |
Hedin_ Skogenracing Elite
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland fre 31 jul 2009, 21:18 | |
| Rubrik: Sv: Ford Sierra Pinto 2.0 T - Poland | |
