 Karmo- '90 Ford Sierra 2.9T
2 posters
karmo
Antal inlägg : 3
Namn : Karmo Jõendi
Från : Estonia
Kör : Estonia
Registration date : 16-09-27
Karmo- '90 Ford Sierra 2.9T Empty
InläggRubrik: Karmo- '90 Ford Sierra 2.9T   Karmo- '90 Ford Sierra 2.9T Icon_minitimeons 28 sep 2016, 20:38
Hello!
I am driving 1990 Ford Sierra.
From factory it was 2.0 74kw. No chia no nothing.
But more then Year ago i bought from my friend a 2.9 cologne v6 engine with turbokit.
It was:
stock 2.9 v6
360cc injectors
284 cam(kent cams)
non hydraulic cam followers
Hx35W turbo
audi wg
oil cooler kit
and coolerkit with Greddy rs bov
and ms1 ecu.
type 9 gearbox
somekind performance clutch
In the beginning i changed all the gaskets and but in all 6 pistons from another engine because 3 of the old ones was broken.
i changed also injectors to twise bigger, now it has 668cc injectors.
in the dyno we had issiues with boost, because at 3000rpm we had over boost problems. Okay wg is stuck, opened it and cleaned and it was okay.
then was alots of issiues with ecu and wiring, wiring was really bad but it altho runned. changed map sensor and added a filter to the sensor and dynoed it to 200kw. because 1 bar boost was max with distributor.
It was clear that it needs new wiring and at least ms2x ecu and that distributor needs to be gone.
so a few months later i bought for 55o€ a cosworth scorpio with bob engine in it.
i tooked for myself ingnition parts and steeringpump, generator, and other wheels to run one belt not 2.
allso front brakes and whole rear axle with big discbrakes and 7.5" diff.
and added vw g3 coilovers to front and vw transporter t4 twoway shocks to back.
Ordered all discs and pads and installed cosworth brackes to the car. now fronts are 278mm and rear 273mm. Stops really good Smile
then i taked all front end in to pieces to install coilpack, crank sensor, cossie trigerwheel and all other componates to run only one belt.
Ordered allso new ecu witch was MS3X v3.0.
then i but sierra to a trailer and was driving to my friend who made new wiring and install ecu and dynotune it aswell.
it made 236kw and 441nm from wheels its about 272kw and 500+nm from engine and because the back of the car is soo light i didnt get good traction and numbers are with spinning wheels on dyno with 5th gear.
engine was driving over 10 000 km then i run to a cooling problem witch was that thermostate did not open and engine went to hot and then i had blown headgasgets and 2 broken pistons (3 and 6) and one of ported head was ruined.
For now the engine is fixed again and ready to go dynotune again.
planning to turn boost up to 1.6 bar hope it holds up. because engine isnt o-ringed.
If that engine wount hold then i go to 2jz engine.
Karmo- '90 Ford Sierra 2.9T 12122439_1045088642192195_2880658990069064820_n
Karmo- '90 Ford Sierra 2.9T 11061327_1045088665525526_5496734579521540031_n
Karmo- '90 Ford Sierra 2.9T 12118807_1045088688858857_8840332903579992711_n
Karmo- '90 Ford Sierra 2.9T 12011187_1045088715525521_299944065333082200_n
Karmo- '90 Ford Sierra 2.9T 11219615_1045088735525519_6981874394277030747_n
Karmo- '90 Ford Sierra 2.9T 12115691_1045088752192184_5378247625609582659_n
Karmo- '90 Ford Sierra 2.9T 10442427_1071117282922664_8201846690260512974_n
Karmo- '90 Ford Sierra 2.9T 12552773_1084215618279497_2945258189628444815_n
Karmo- '90 Ford Sierra 2.9T 12548890_1084735718227487_968509269099849496_n
Karmo- '90 Ford Sierra 2.9T 12592727_1090018994365826_3004296890308783747_n
Karmo- '90 Ford Sierra 2.9T 14449969_1277307288970328_2296870980082266481_n
Karmo- '90 Ford Sierra 2.9T 14463241_1277307308970326_4684133676989084289_n
Karmo- '90 Ford Sierra 2.9T 14495426_1277307335636990_3843074047061152189_n
Allmost back in one piece
Karmo- '90 Ford Sierra 2.9T 14462898_1277307265636997_4962261267864128621_n
The Key to Happyness!
Karmo- '90 Ford Sierra 2.9T 12715432_1103431846357874_1319968628351965781_n
InläggRubrik: Sv: Karmo- '90 Ford Sierra 2.9T   Karmo- '90 Ford Sierra 2.9T Icon_minitimesön 23 okt 2016, 11:24
At most you can have 1,2bar of boost without o-ring. 1bar to be safe,at 1,2bar they will burst sooner or later.
I have tried a lot
karmo
Antal inlägg : 3
Namn : Karmo Jõendi
Från : Estonia
Kör : Estonia
InläggRubrik: Sv: Karmo- '90 Ford Sierra 2.9T   Karmo- '90 Ford Sierra 2.9T Icon_minitimemån 24 okt 2016, 13:30
I have it running for few weeks now.
1.7 bar boost and havnt broke yet. But in first 100 kilometers i broke my gearbox again. That t9 isn't good at all.
Now i bought bmw 6 speed. Hope that it going to hold.
With engine i made that mistake that heads arent ported and that engine doesnt make power at all. About 180-190kw from wheels.
But good to drive 402m in 13.3s
InläggRubrik: Sv: Karmo- '90 Ford Sierra 2.9T   Karmo- '90 Ford Sierra 2.9T Icon_minitimetis 25 okt 2016, 19:32
If you are running 1,7 bar of boost and it´s holding together it´s remarkable.
Congratulations Smile
karmo
Antal inlägg : 3
Namn : Karmo Jõendi
Från : Estonia
Kör : Estonia
InläggRubrik: Sv: Karmo- '90 Ford Sierra 2.9T   Karmo- '90 Ford Sierra 2.9T Icon_minitimeons 26 okt 2016, 19:31
Yes. 1.7 bar of boost. Hope to get some pictures or video of that gauge.
Now i have to work alot to upgrade some more stuff on car and build another engine with bigger turbo.
» Ford Sierra Vs Ford Fiesta
» Bromsfunderingar Ford Sierra
» ford sierra
» Väghållningsproblem Ford Sierra -93
