 B: Adrian Hall’s 1978 Ford Escort MKII
2 posters
B: Adrian Hall’s 1978 Ford Escort MKII Empty
InläggRubrik: B: Adrian Hall’s 1978 Ford Escort MKII   B: Adrian Hall’s 1978 Ford Escort MKII Icon_minitimesön 30 dec 2012, 11:55
Källa: http://www.speedhunters.com/2012/10/a-car-is-for-life-not-just-another-ford-escort/
ENGINE
1990 Cosworth YB; 2150cc; 12.5:1 Compression; HT Racing Ported Head; Kent Cams & Gears; Cosworth Valves; Isky Valves; Titanium Retainers; Cosworth Solid Lifters; Cosworth Head Bolts; Cosworth Headgasket; Gates Timing Belt; HT Racing Machined Block; Cosworth Pistons; Cosworth Con-Rods; Cosworth Con-Rod Bolts; Steel Billet Crank; Cosworth Bearings; HT Racing Pulleys; Maidstone Sports Cars Custom Engine Mounts; Billet Core Plugs; Carbon Fibre Air Intake; Cosworth Slide Throttle Bodies; Four Gallon Alloy Fuel Tank; 2 x Facet, 2 x Bosch High Pressure Fuel Pumps; Cosworth Fuel Pressure Regulator; Cosworth Fuel Rail; Bosch Green Fuel Injectors; Aero-Spec Fuel Lines; Specialist Exhausts Custom One-Off Headers; Specialist Exhausts One-Off Exhaust; Specialist Exhausts One-Off Alloy Rear Box; NGK Spark Plugs; Duratec Coil Pack & Leads; Dry Cell Red Top Battery; Dry Sump; Behr Oil Cooler; Cosworth Oil Filter; Valvoline 20w50; Pro Alloy One-Off Radiator; Silicone Radiator Hoses; Maidstone Sports Cars One-Off Wire Harness; Carbon Engine Cover;
ENGINE MANAGEMENT
MoTeC ECU; Stack Dash & Tachometer; Racetech Water Temperature & Oil Pressure Gauges; Battery Kill Switch;
DRIVELINE
Quaife 5 Speed Dog Box; Quaife Gears; Tranex Differential; Quaife Driveshafts; AP 7.25 Twin Plate Clutch; Lightened Flywheel; Quaife Shift Lever; Shortened Prop Shaft;
SUSPENSION / CHASSIS
MSC Nitron Escort Shocks Front & Rear; Nitron 600lb Front Springs; Nitron 400lb Rear Springs; Nitron Top Mounts; Fully Rose Jointed Front Adjustable Links; Fully Rose Jointed Rear Adjustable Links; Quick Steering Rack; Blade Type Front Sway Bar; Blade Type Rear Sway Bar; Rose Jointed Drop Links; Maidstone Sports Cars Custom Built Roll Cage; Custom 5 Link;
BRAKES
AP Four Piston Front Calipers; AP Two Piston Rear Calipers; AP Racing Brake Pads; AP 320mm Front Discs; AP 280mm Rear Discs; Braided Brake Lines; AP Master Cylinder; Maidstone Sports Cars Custom Pedal Box; Motul 660 Brake Fluid;
WHEELS / TYRES
Front: Compomotive Split Rims 16×11 w/ Avon 11″ Slicks
Rear: Compomotive Split Rims 16×13 w/ Avon 12″ Slicks
Compomotive Nuts & Studs
INTERIOR
Corbeau Pro Race Driver’s Seat; Corbeau Passenger Seat; Corbeau Seat Rails; Five Point Harnesses; Sparco Steering Wheel & Hub; Racetech Steering Wheel Quick Release; Quaife Shift Knob; Carbon Pedal Covers; Carbon Fibre Interior;
EXTERIOR
Ford Diamond White; Complete Zakspeed Modified X-Pack Kit; Maidstone Sports Cars Custom Carbon Fibre Under Tray; Maidstone Sports Cars Custom Carbon Fibre Rear Diffuser; Maidstone Sports Cars Custom Built Rear Spoiler; Carbon Fibre Doors; Carbon Fibre Roofskin; Carbon Fibre Bonnet; Carbon Fibre Boot; Maidstone Sports Cars Graphics; Custom Plastic Windows;
PERFORMANCE
280BHP @ 8,500RPM; 180lb/ft @ 5500RPM; 780KGs;
B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-26B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-27B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-25B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-24B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-23B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-22B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-21B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-20B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-18B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-16B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-13B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-12B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-11B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-10B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-9B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-8B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-6B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-4B: Adrian Hall’s 1978 Ford Escort MKII Maidstone-Ford-Escort-1
InläggRubrik: Sv: B: Adrian Hall’s 1978 Ford Escort MKII   B: Adrian Hall’s 1978 Ford Escort MKII Icon_minitimesön 30 dec 2012, 23:51
Vilken bil! Så jävla läcker....
» Prozac - Ford Escort MkII 9,59s 238kmh
» Eriksson - Ford Escort MkII (dags för besiktning)
» B: Ford escort mk2
» Crille - En elak jävel (Ford Escort MKII 3.0 Turbo)
» B: Lite Escort mkII...
Skogenracing.com :: Skogenracing Society :: Bilder/Filmer-
