 2.9 v6 N/Ā with megasquirt
cosworth team ruse
Antal inlägg : 25
Namn : daniel
Från : bulgaria
Kör : ford sierra 2.0 dohc
Registration date : 09-11-24
InläggRubrik: 2.9 v6 N/Ā with megasquirt   tis 20 mar 2012, 19:05
hello, i have a 2.9 12v engine and i want to run it just with megasquirt 1 without turbo, n/a engine just to use mega to control the engine .i see you have a map for 2.9 turbo but will this work fine on natural aspirated engine ? any diagram for wiring the megasqurt to the instalation this is the mega http://audibg.com/forum/index.php?showtopic=82466
InläggRubrik: Sv: 2.9 v6 N/Ā with megasquirt   tis 20 mar 2012, 21:25
Yes it will work but you need bigger injectors (350cc) if you don´t want to adjust anything
cosworth team ruse
Antal inlägg : 25
Namn : daniel
Från : bulgaria
InläggRubrik: Sv: 2.9 v6 N/Ā with megasquirt   tis 20 mar 2012, 22:24
big injector without turbo, what hapen ot normal run ?,if i want to use stock injectors 145cc i think was, what i have to change to megasquirt to work
InläggRubrik: Sv: 2.9 v6 N/Ā with megasquirt   ons 21 mar 2012, 06:41
Nothing happens, i you want to use stock injectors you need to retune most of the map
cosworth team ruse
Antal inlägg : 25
Namn : daniel
Från : bulgaria
InläggRubrik: Sv: 2.9 v6 N/Ā with megasquirt   fre 23 mar 2012, 22:34
îę thancks mikael
