Antal inlägg : 13 Age : 34 Namn : Jaanis Från : Latvia Kör : Ford Sierra 2.0i ohc Registration date : 11-07-20
Rubrik: Pinto knocking tor 08 mar 2012, 17:09
Here are lots of people who has some experience with these engines, so what is that awful sound? I know it's similar to bad valve adjustment, but not in this case, because clearence is set as specified. What else could it be, any thoughts?
Rubrik: Sv: Pinto knocking tor 08 mar 2012, 18:31
It´s your camshaft, you need to replace it and change the lifters
Johnny T. Skogenracing Small
Rubrik: Sv: Pinto knocking tor 08 mar 2012, 21:59
What can go wrong with valve lifters?
Rubrik: Sv: Pinto knocking tor 08 mar 2012, 22:53
If the camshaft is wearn out the lifters go to ! Very common problem on the pinto. Make sure to change the oil spraybar and do the oil changes often after you changed the camshaft and lifters.
Rubrik: Sv: Pinto knocking fre 09 mar 2012, 16:02
Ok, thank you both for reply. Will check condition on camshaft and lifters.
