 Crank case venting under boost?
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
Kör : 1992 Ford Ranger
Registration date : 11-01-20
Crank case venting under boost? Empty
InläggRubrik: Crank case venting under boost?   Crank case venting under boost? Icon_minitimemån 02 jan 2012, 16:29
Getting everything setup for the 2.9 turbo, and want to make sure I get it right this time as I may have had bugs in my 4.0 setup.
Right now the PCV (RH valve cover) valve runs into the front side of the throttle plate. There is a vent for the LH valve cover that also runs infront of the throttle plate.
When I plumbed the intake pipes on the 4.0L I ran the PCV in the stock location on teh LH cover, and the breather tube off the fill tube I ran into the low pressure intake tube. My blow off valve I also ran back into the intake on the low side also.
Pretty much the same setup as the first diagram in the link, minus the catch can.
http://www.sr20-forum.com/information-library/44727-crank-case-ventilation-fully-explained-turbocharged-edition.html
Is this a safe setup to use or is it problematic without the catch can?
InläggRubrik: Sv: Crank case venting under boost?   Crank case venting under boost? Icon_minitimemån 02 jan 2012, 22:25
Move the PCV to the turbointake instead. You don´t need the catch with that setup
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Crank case venting under boost?   Crank case venting under boost? Icon_minitimetis 03 jan 2012, 03:22
So like this?
Crank case venting under boost? Crankvent
InläggRubrik: Sv: Crank case venting under boost?   Crank case venting under boost? Icon_minitimetis 03 jan 2012, 09:19
Yes
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Crank case venting under boost?   Crank case venting under boost? Icon_minitimetis 03 jan 2012, 15:39
Cool, makes perfect sense. PCV acts like it normally would. The other thing that comes into play is the other side has a filter. I've got another filter that I can link both covers together will to eliminate any trapped gasses in the one cover.
Just need to drill another hole is all.
