 Mercury Khronos
Gå till sida : 1, 2, 3, 4  Nästa
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
Kör : 1992 Ford Ranger
Registration date : 11-01-20
Mercury Khronos Empty
InläggRubrik: Mercury Khronos   Mercury Khronos Icon_minitimefre 09 sep 2011, 15:51
This is where I'm going to officially start my build post.
I've been collecting parts, designing, and secretly planning my build. I now have a direction and a slue of parts. Time to get building.
Here is what I started with.
1992 Ford Ranger 2wd extended cab short box.
Mercury Khronos SCCATruck001
I swapped in a 2.9L V6 with a 5 speed Mazda Transmission.
Mercury Khronos 53a9d59c
Got it all running and on the road. Truck runs great. typical lifter clatter though.
Did a shackle flip to lower the back so the truck sits level. Dropped the truck about 2" in the back.
Mercury Khronos Photo-8
Designed an axle fip kit to lower the back the 8" needed to clear the tires and keep the truck level.
Mercury Khronos Springpads
Mercury Khronos Springpad2
With the extra drop out back I need to notch the frame. Insert a Monster notch.
Mercury Khronos Rear
Ordered all the parts to be Laser cut.
Mercury Khronos 92aeabb5
Mercury Khronos B925461b
Mercury Khronos 76537003-1
Mercury Khronos 489e25b3
Bought a set of 3" drop beams for the front. This will lower the front 3" with the stock coil springs.
Mercury Khronos F7a872d5
Now you ask why the difference is lowering heights? Simple. I plan to run a 33 x 12.5" tire on the back and a 205/70 on the front. Tires are on order. Picked Firestone Destination AT's as there were only a few tire companies that made the sizes I wanted with the same tread pattern.
Mercury Khronos FireDestat
Here is what it should look like when lowered and on the right size rubber.
Mercury Khronos ChopTruck
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimefre 09 sep 2011, 16:08
Here are some of the things I have been working on.
Time to start the Mercury part.
Cut the Letters out of Fiberglass on a water jet and epoxied them onto the tailgate skin.
Mercury Khronos 63005559
Smaller set for the grill
Mercury Khronos Grill
Both finished.
Mercury Khronos Photo-8-1
Started on changing the headlights. I liked the different look that the German Spec Explorer had and wanted to keep it looking different than the other trucks here.
Mercury Khronos Germanex
Cut the light apart and inserted new sealed beam headlight.
Mercury Khronos Lights002
Made cardboard fillers to get an idea of shape I needed for the bezels.
Mercury Khronos 6c88f607
Next to the stock headlight
Mercury Khronos 9cf5da43-1
Completed the other side in the same manner.
Mercury Khronos Photo-8-4
Got around to installing the tailgate skin and grill.
Mercury Khronos Photo-8-3
Mercury Khronos 9b46b238
Lets see what the new lights look like with the new grill?
Mercury Khronos 667ae6b8
Start the process of making a mold for the fiberglass pieces.
Mercury Khronos 4442398e
Mercury Khronos 01e94e0e
Needs some bodywork on the molds before making parts.
Mercury Khronos B452fb39
This is where I am at right now
Except for having to change out a couple suspension parts this week because of the old ones finally letting go.
Mercury Khronos Old
Mercury Khronos New
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimefre 09 sep 2011, 16:28
Parts I have for the engine stages.
I have new lifters and pushrods for the 2.9L and a new High volume oil pump. Also have a gasket kit for the engine for when these parts get put on. Also have some 260cc injectors.
I had picked up a MS1 kit and have assembled it but having issues with loading the tune to it. It connected to upload the MS1 Extra firmware, but won't connect for the tune.
Put it on the back burner for now.
Picked up a Vortech 12:1 FMU kit and a recalibration kit for 10:1. Also got a 255 Lph fuel pump. Both of these are in the mail. Should have them next week.
Why the FMU, big fuel pump, Megasquirt, and 260 injectors you ask? Simple fact of the matter is that I want to turbo charge this truck. Have you guys to thank for the bad ideas.
I have a turbo setup I previously built for another truck, but removed it after cracking a head and having turbo oil return issues.
Plan to mount the turbo on the 2.9L.
Turbo is a T3/T4 from a Datsun 280ZX. I've got a 12 x 12 intercooler I picked up a while back and will add that to the mix as the original setup didn't use one, but that was 3 PSI. I plan to run this one at 10-15 PSI.
I've had lots of these parts for a while now and Just need to get time to install it all.
Once the FMU and fuel pump get here it's going to get crazy, as I'll be working long nights/weekends to get this stuff installed.
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimesön 18 sep 2011, 02:03
Drop Beams installed lastnight. Got the alignment close so I can drive it. I may chop the coils down a bit to adjust the camber. Brakes work and I massaged the fenders a bit so the tires don't rub. The beams and knuckles came from a 97 Ranger so I got a free upgrade to the twin piston calipers.
Mercury Khronos 3d64f114
Mercury Khronos 5fd05570
Mercury Khronos 7511d851
Mercury Khronos 74647a67
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimemån 26 sep 2011, 14:18
Chopped 3/4 loop from the coils
Mercury Khronos D829671f
Installed a 255 lph fuel pump. Put the new fuel tank straps on.
Gave the truck some color.
Mercury Khronos 7ee94f19
Mercury Khronos 4359f2e1
Mercury Khronos 5ec27832
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimeons 05 okt 2011, 20:40
Found two 2.9L engines to play with. One will get built up with the turbo and go into this truck. Traded two 5.0L truck engines for them.
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimeons 05 okt 2011, 21:27
nice job man! Smile
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimefre 07 okt 2011, 12:50
wheels
Mercury Khronos A9121f61
hood
Mercury Khronos 81c04f43
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetis 11 okt 2011, 14:47
Picked up a 2.9L on the weekend and started to play around with it.
First thing found was I have to move the alternator.
Mercury Khronos 1413d11b
Mercury Khronos 91b15591
Other than that it seems to fit nice.
Oil drain back will be easy to route into the valve cover.
Mercury Khronos 91e4dcd9
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetis 11 okt 2011, 16:11
Also have a treat for you guys. Something I got a couple months back that I can finally stick on the truck.
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 13 okt 2011, 14:04
Here you can see where the alternator is. Its positioned below the servo pump.
https://redcdn.net/ihimg/f/151/fotos452.jpg/
In your case it would be the best way to refit yours to where the European alternator is (if you don't have any steering servo that is in the way). Maybe its easier to get hold of an European intake & plenum instead?
You could find it in the Merkur Scorpio, if you find any! Neutral
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 13 okt 2011, 14:38
Don't have the room there between the frame rails. My power steering pump is on the other side. I'm thinking of mounting it above where the air conditioning compressor was mounted.
Mercury Khronos B9cea1f8
Here is the surprise for you guys........
Mercury Khronos 50a9d9bc
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 13 okt 2011, 14:47
Why not where the AC is? Smile
Nice sticker! Very Happy
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimemån 17 okt 2011, 18:42
Got a bunch of little things painted over the weekend.
Mercury Khronos D5eefb95
Mercury Khronos 930baa33
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimeons 19 okt 2011, 14:28
Got some stuff done last night.
Mercury Khronos E89837ed
Since I have welding to do on the tailgate. I may as well do it right.
Mercury Khronos 47698794
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimeons 19 okt 2011, 15:28
Found this picture for alternator location
Mercury Khronos Build00004
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimesön 13 nov 2011, 15:01
Got some stuff done this weekend.
Rolled into the shop like this.
Mercury Khronos B05c6fe3
Couple hours later.
Mercury Khronos 1fcceeb0
Mercury Khronos 3cdeb1a2
Mercury Khronos 8ccb97e3
Mercury Khronos 460a898c
Mercury Khronos Dec7a2ca
Rolled out like this.
Mercury Khronos 49a6fa80
Mercury Khronos 782cfe2f
Mercury Khronos 9a71c717
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimeons 16 nov 2011, 22:49
The 33's were just a bit too big so I mounted up a set of 31's I had.
Gave the truck a bit of a wash.
Mercury Khronos 1fe3cdab
Mercury Khronos 7c00d95a
Mercury Khronos Ef1ba41d
Mercury Khronos 6f75c7b4
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 17 nov 2011, 09:07
nice man! keep up the good work and updates
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 24 nov 2011, 15:50
Changed the wheels.
Mercury Khronos 81096800
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimesön 18 dec 2011, 00:42
Getting back into it and got the alternator relocation bracket welded on.
Mercury Khronos 8b832376
Mercury Khronos 713c7129
Mercury Khronos 1e67a01c
Mercury Khronos 043a5743
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimesön 18 dec 2011, 00:44
Nice work! Smile
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimetor 22 dec 2011, 22:06
Moved a few things around to make room for future changes. The Coil isn't normally there! Wink
Mercury Khronos 1b352dd4
Charcoal can moved. clown
Mercury Khronos 465f6a6c
Washer bottle/overflow moved back to give lots of room for new battery location Mercury Khronos Av-26
Mercury Khronos Ae6cdf20
Copykat
Copykat
Antal inlägg : 125
Namn : Joel
Från : Kanada
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimefre 30 dec 2011, 00:36
Was doing some brain storming lastnight looking at the engine on the stand. The oil fill is too close to the turbine and will melt the cap. I never had this problem on the 4.0L so I got to thinking. and pulled out a spare set of 4.0L valve covers. Eurika moment #1 was they have the same bolt pattern and the fill tube is farther forward putting it closer to the compressor , not bad and the PCV relocation should be a bid deal. But then Eurika moment #2 hit me. Why not swap the 4.0L covers left to right.........duh! Just swap the stock 2.9L valve covers! Anyone tried this by accident.
2.9L covers flipped left to right. No mods needed.
Mercury Khronos 27e97f2b
Mercury Khronos 8e440200
InläggRubrik: Sv: Mercury Khronos   Mercury Khronos Icon_minitimefre 30 dec 2011, 01:40
that's smart thinking dude Smile any plans of painting the rest of the car?
Mercury Khronos
Sida 1 av 4Gå till sida : 1, 2, 3, 4  Nästa
