 My DIY EFI
markobcars
markobcars
Antal inlägg : 19
Namn : Marko
Från : Borovac
Kör : Ford Sierra 2.9 cosworth
Registration date : 11-08-25
My DIY EFI Empty
InläggRubrik: My DIY EFI   My DIY EFI Icon_minitimefre 02 sep 2011, 01:09
Hello!
I would like to show You my diy efi system...
I can design custom electronics from PCB-s to programming PIC microcontrollers so i made my own(not a copy) stand alone fuel injection unit and ignition unit... it was finished some 7 years ago...
It is a very fast unit and has really high resolution maps,from 127 to 255 points for every sensor... It is very easy to get running if You know what you're doing...
-adaptable to almost every engine out there
-military spec electronics inside with wide temperature range
-accepts only custom hall cranck sensors which I make custom for the application
-integrated real time data logger
-boost controll
-very high computing power allows high sensor update
-real time programming with hand held 4 row LCD/key board so You don't need laptop to set things up...
-it DOESN'T support closed loop lambda operation due to very slow lamba reaction time
I could go on and on so if there is anything that You would like to know please ask...
The system will be for sale next year but not for little money... price will be little above 1200Euro for the whole management system....
I have some great experience with DTA and AEM but those systems offer so much options that they suffer from high lack of computing power and resolution which lowers engine performance too much for my taste...
When tested side by side You can tell the difference Smile
The system has been tested on sierra pinto and cosworth turbo engines and it outperformed everything else we tried...
Here are some pictures of the test boards and screens...
RTDL
boost controll
this is the crank shaft position sensor magnet carrier
markobcars
markobcars
Antal inlägg : 19
Namn : Marko
Från : Borovac
My DIY EFI Empty
InläggRubrik: Sv: My DIY EFI   My DIY EFI Icon_minitimetor 10 nov 2011, 23:57
First ignition of my second test car with new options in ECU like real time mapping...
Also hand held programmer has been redesigned...
https://www.youtube.com/watch?v=8YnqzaN_0NU&feature=youtu.be
My DIY EFI Bild0796a.th
My DIY EFI
