 Newbie and a Novice
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
Från : Retford, Nottinghamshire, UK
Kör : MK3 Capri 2.8i V6
Registration date : 10-10-29
Newbie and a Novice  Empty
InläggRubrik: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 21:41
Hey guys...
I LOVE YOUR WORK AND I AM A HUGE FAN...... Your all absolute geniuses
I am a newbie of sorts to Turbos and high performance engines but i have a Capri 2.8 V6 and its just a Toy and for the winter i would like to tackle a project and i have been thinking about a Ford V6 2.9 BOB engine, i am in the research mode at the moment before i take anything on i want to know what i am doing...
I admit i would love to fit a turbo OHH HOW I WOULD but i dont think i will be able to manage that with being a bit of a novice...
Any help or advice you can offer would be amazing....
Here is the Capri currently named the Old Spice Capri but changing the name now to Mental Spice Capri :-) The reason for the Old Spice is, well i won the car in a radio competition :-P
Newbie and a Novice  Pbucket
Yep it has a built in Old Spice holder which comes in handy for coins lol
Thanks for looking and i hope to hear from you all
Chris
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 21:47
Nice car!
I suggest the cologne 2.9 if you want to try out turbo. With the right parts i have maps for megasquirt that will work right away
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:07
Hey Mikael
You are a master amongst men, your Capri is one of the best i have ever seen :-)
Thank you for your nice comment :-D
the Cologne 2.9 is that the one that is found in the Ford Granada, XR4 and Scorpio (BOA engine?)
what parts would you recommend for a starter build and then progress to a turbo both mechanical (mounts, gearbox, etc), electrical and vacuum? what brakes would you advise and how to keep it on the road.... i would like to aim for 300bhp if that is possible to start
I know you cant give away all yoru secrets but a few would be great :-D
my email is chris_gray1980@hotmail.co.uk feel free to use it YODA of the CARWARS SAGA
Chris
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:15
Cologne 2.9 that i mean is the 12valve engine common in sierra and scorpio
A turbo from a lorry, for example Garrett gt40 or Holset HX35
Simple exhaust manifold
350cc injectors
Megasquirt 1 v3.0
Walbro 255 fuelpump
Reinforced cosworth clutch
Intercooler
With this you can achive 350bhp easy
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:19
now that sounds like a cracking set up :-D what gear box set up would you go for? and the wiring harness would you use the 12v loom out the donor car? are there any things i would need to worry about for example PATS or VIS, etc
Cheers for the info on the forum i will check it out for sure :-D
Thank you for your patience
Chris
Senast ändrad av chris_gray1980 den fre 29 okt 2010, 22:24, ändrad totalt 1 gång
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:21
To high compression and it´s expensive to change parts in the 24v engine to achive lower compression.
there is a thread in this section that diskuss turbocharging v6
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:26
oh to add to teh above do i need to beef up the internals or make any alterations while the engine is out and being cleaned up??
Again thanks for your patience
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 22:30
on the 12v you can mount the turbo without dissembling the engine
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimefre 29 okt 2010, 23:06
would you up rate anything at all lol..... if not that means it will be a lot cheaper lol.....
I assume (excuse my stupidity) the Maguire Squirt is a new ECU for the set up to allow the turbo set up :-)
did you make a lot of custom parts, manifolds, turbo pipes, etc
ohh how i cant wait to get started but god im excited but nervous as well lol
Thanks again for all the information i really appreciate.
and your English is excellent
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimelör 30 okt 2010, 10:31
My paycheck ain´t that big so with limited money it´s necessery to make own manifolds and so on Smile
The standard fuelsystem can´t handle turbocharging. An aftermarket fuelsystem is needed and Megasquirt is a cheap one
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimelör 30 okt 2010, 11:16
Very nice car you got there. And if you listen to Mikael you can´t fail Wink
Newbie and a Novice  Whistlin
chris_gray1980
Antal inlägg : 6
Namn : Chris Gray
InläggRubrik: Sv: Newbie and a Novice    Newbie and a Novice  Icon_minitimemån 01 nov 2010, 11:24
Hey Combathenke,
Thank you for the nice comment :-D
Mikael is an absolute genius and i an extremely grateful for all his help :-D
i am starting to feel taking a project on like this may be above me both engineering and cost wise, i have viewed a few other 2.9 conversions and they seem extremely complex, the most expensive part looks like it could be the mega squirt but I SO BADLY want to hit 300BHP
frustrated.......
Thanks again :-D
Newbie and a Novice
