 Pinto Build seeking information
4 posters
Therkelsendk
Antal inlägg : 3
Namn : Nikolai
Från : Denmark
Kör : sierra
Registration date : 18-06-21
Pinto Build seeking information Empty
InläggRubrik: Pinto Build seeking information   Pinto Build seeking information Icon_minitimetor 21 jun 2018, 23:44
hi i am currently seeking information for my projekt pinto turbo for the winter
right now ive got a pinto with a 2871 and a custom made manifold i have planned to go with a megasquirt ecu, and a rotary ignition to coilpack conversion
as you can see i have startet a little bit iam seeking around 250-300hp i am going all the way with arp headstuds and a cometic headgasket
btw i will be going 99 oktane depends if theres a diffrence from 95 ofc
should i go internal or external wastegate
i need some help to find out what gasket thickness i need
should i stay org with the cam? aswell what about the valve springs upgradable or
can i buy another intake manifold somewhere?
should i stay orginal with the internals or go YB pistons and rods or only one of them?
this is my first build on a pinto so if there is anything i should be careful about or any good ideas please tell me Smile
Pinto Build seeking information 32705410
Therkelsendk
Antal inlägg : 3
Namn : Nikolai
Från : Denmark
Kör : sierra
InläggRubrik: Sv: Pinto Build seeking information   Pinto Build seeking information Icon_minitimemån 17 sep 2018, 22:25
nobody that can help ? Smile
rwd
Antal inlägg : 2
Namn : Nic
Från : England
Kör : 100e
Registration date : 16-02-28
InläggRubrik: Sv: Pinto Build seeking information   Pinto Build seeking information Icon_minitimefre 02 nov 2018, 18:38
Try looking on the Facebook page
Antal inlägg : 659
InläggRubrik: Sv: Pinto Build seeking information   Pinto Build seeking information Icon_minitimefre 23 nov 2018, 19:12
I would go with yb pistons and rods if the turbo you use has an internal wastegate then use it no need for external at 300hp,
You dont need a cometic gasket, and you should use arp bolts, you can build your own intake manifold, just looks at the threads in this forum. There are alot of pinto builds.
A better clutch is also needed
Therkelsendk
Antal inlägg : 3
Namn : Nikolai
Från : Denmark
Kör : sierra
InläggRubrik: Sv: Pinto Build seeking information   Pinto Build seeking information Icon_minitimelör 05 jan 2019, 23:29
okay but i see here in denmarks the yb pistons and rods are hard to come by should i buy some from burtonpower?
Machu
Antal inlägg : 2
Namn : Madis
Från : Estonia
Kör : OHC
Registration date : 16-05-11
InläggRubrik: Sv: Pinto Build seeking information   Pinto Build seeking information Icon_minitimetor 10 jan 2019, 16:17
I think you should buy pistons and rods from burton! Expensive but good quality. There is this page Motomobil.de, there you can find original parts.
» 2.9 12v turbo information
» Information om orginal kam?..
» Information om Ford´s V6 motor...vart hitta?
» Volvo engine build up questions
» 205 pinto anybody seen this before??
