 Ford Capri 2.3 T
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
Registration date : 10-05-31
Ford Capri 2.3 T Empty
InläggRubrik: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 22 jun 2010, 12:55
Hi from Bulgaria i`m Geo Slavov and i have a Capri mk 3
well i fond it 3 years ago like that
Ford Capri 2.3 T 012261602
Ford Capri 2.3 T 012261603
Ford Capri 2.3 T 012261622
me and my father are owner of a small garage were we restore OSF fords
and this the when the mk 3 is in it
Ford Capri 2.3 T 012261708
Ford Capri 2.3 T 012261699
it originaly came with 1600 ohc
Ford Capri 2.3 T 012261691
Ford Capri 2.3 T 012261636
Ford Capri 2.3 T 012261644
then i changed it with 2000 dohc efi from sierra with mt 75 gearbox
Ford Capri 2.3 T 012261650
Ford Capri 2.3 T 012261591
Ford Capri 2.3 T 012261598
Ford Capri 2.3 T 012261651
Ford Capri 2.3 T 012261588
then i dacided to paint it up
Ford Capri 2.3 T 012261665
Ford Capri 2.3 T 012261686
Ford Capri 2.3 T 012460309
Ford Capri 2.3 T 012473331
Ford Capri 2.3 T 013548701
Ford Capri 2.3 T 013548821
Ford Capri 2.3 T 013548862
Ford Capri 2.3 T 013548880
then i was hitted by an idiot
Ford Capri 2.3 T 015436849
then i fix it again
Ford Capri 2.3 T 015436855
then i went a little track day and two competitions for old skool cars
and i fond all of the suspension problems in it
well i made a whole new front suspension ... adapted from sierra
i reversed left and and right control arms and the connecting rod went in front , it`s also from sierra and its 28 mm thick.
i also adapted fron discs form escort rs turbo and mondeo calippers
well now i`m going to put a trottle bodies and megasquirt 2 , to increase a bit more power .and may be a inderpendent rear suspension from sierra with lsd , cause... i need lsd . So far so good .... so what Smile
`il be using it as a car for classic car competitions .
Senast ändrad av deshi den fre 30 sep 2011, 09:39, ändrad totalt 1 gång
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 22 jun 2010, 14:21
Wow really nice car paint!
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 22 jun 2010, 15:39
thanks , it`s the first painting i `ve made
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 22 jun 2010, 16:52
Wow nice, The first paint i did lookt just like my grandma pantied the car Ford Capri 2.3 T Tihi
Sköld
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
Registration date : 08-08-17
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 22 jun 2010, 20:45
The car looks just fantastic in that General Lee orange? will be fun to see how you did with the suspnsion,good luck Smile
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetor 24 jun 2010, 23:01
i have sime pics from the making of the front suspension well the most important thing was this
Ford Capri 2.3 T 019362976-big
Ford Capri 2.3 T 019362980-big
Ford Capri 2.3 T 019362981-big
Ford Capri 2.3 T 019362983-big
here i wanted to see if t fits good ... so it did Smile
Ford Capri 2.3 T 019362984-big
Ford Capri 2.3 T 019362986-big
Ford Capri 2.3 T 019362987-big
Ford Capri 2.3 T 019362988-big
Ford Capri 2.3 T 019362989-big
well as you can see this cames from sierra and i cut the left and the right end of it.then i welded some new metal sheets and then i made the holes for the control arms in them.welding new metal sheets there alows you to choose the place for control arms ... well in my case this was it :)well as i said in previos post i also use carrier hubs from sierra and and escort mk 5 / fiesta suspension... it can be used from sierra too but these from escort are shorter ... and they are shorter. Smile
so ...as you can see here in the folowing pictures the pc pherson
Ford Capri 2.3 T 016952694-big
Ford Capri 2.3 T 016952693-big
so these are fiesta shocks and sierra hub carriers + now eibach springs and escort rs turbo disc brakes.and i dont use any spacers ford the wheels Smile
hope it `ll be helpful... for you too
cheers Smile
Sköld
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 29 jun 2010, 23:46
So sweet,what offset do you get with the Sierra hubs compared to the old Capri ones?
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimeons 30 jun 2010, 00:00
the offset is 6 cm more than the original one for each hub... actually the front is 12 cm wider ... in compare to the stock one
Sköld
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimeons 30 jun 2010, 00:06
Ah must try this myself sounds to good to be true Wink Are you using the Capri steering rack?
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimeons 30 jun 2010, 00:07
some pics with the new front susp.
Ford Capri 2.3 T 26511_116831125009760_100000486188135_223222_133451_n
Ford Capri 2.3 T 26511_116831151676424_100000486188135_223227_7041735_n
and 1 compared to my father`s mk 1
Ford Capri 2.3 T 30707_1483511485733_1172234620_1376467_7428138_n
no i`m not , i`m using rack from sierra , you can also use a hydraulic rack ... and the steering is custum , i`m using part of sierra , part of capri and in the middle from fiesta Smile... there was no other way
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: :)   Ford Capri 2.3 T Icon_minitimemån 30 aug 2010, 19:27
So i gave up from dohc 2000 for now cause i both a 2300 ohc turbo engine from sierra xr4 ti , i liked it when it was on sierra and i am going to fit in the capri may be next week Smile
Ford Capri 2.3 T 29694_1286146834597_1257953357_30650128_6741656_n
Sköld
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimemån 26 sep 2011, 22:42
Did this car die or is it still rocking around? confused
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 27 sep 2011, 05:47
No it`s not dead , i`m enjoing the turbo power now ... soon i`ll post some pics here Smile, and what about your car ... how far are you ?
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimetis 27 sep 2011, 09:53
So i took the 2.0 DOHC away and swaped the 2.3 Turbo OHC. Well as you can se on the pics, the real breakdown was the wiring ,
Me starting to rip out the dashboard and the loom from DOHC...
Ford Capri 2.3 T 022706775
2.3wiring
Ford Capri 2.3 T 022706822
the messs
Ford Capri 2.3 T 022706844
Ford Capri 2.3 T 022706838
Ford Capri 2.3 T 022706816
Ford Capri 2.3 T 022706813
Ford Capri 2.3 T 022706811
Ford Capri 2.3 T 022706810
Ford Capri 2.3 T 022706794
Ford Capri 2.3 T 022706793
Engine IN
Ford Capri 2.3 T 022706781
Ford Capri 2.3 T 022706776
The moment when i started with engine wiring and sensors
Ford Capri 2.3 T 022706785
Ford Capri 2.3 T 022706788
Ford Capri 2.3 T 022706795
Ford Capri 2.3 T 022706796
the engine bay looks like that now
Ford Capri 2.3 T 025142523
i`m intending to hide all of wiring to have a better look ...
so it was originaly coupled with automatic gearbox and no intercooler and the level of boost was 0.5
now `im running on 1 bar boost and it goes nuts , well i think it is a a good and reliable engine
now i use MT 75 gearbox
last month i received some stuff for the engine from USA including all new gaskets , piston rings, timingbelt kit , spark plugs , cables , distributor , engine bearings and many other
esracing
esracing
Antal inlägg : 33
Namn : Erik
Från : black forest, germany
Kör : Ford Capri mk1 OHC
Registration date : 12-11-02
InläggRubrik: Sv: Ford Capri 2.3 T   Ford Capri 2.3 T Icon_minitimelör 03 nov 2012, 15:57
wow, that is great work! I like it very much. How much hp makes the 2.3 Ohc Turbo ?
I read that you moved to Reutlingen in Germany. There lives a friend of me and he had a Ford Capri mk3 2.8 Turbo with around 300Hp.
Ford Capri 2.3 T
