 Help! Head gasket for Pinto...
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
Registration date : 08-12-09
Help! Head gasket for Pinto... Empty
InläggRubrik: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimelör 19 jun 2010, 19:21
Hi!
I've got a problem... My head gasket by Victor Reinz (for Cosworth) said "bye bye..." and I don't know why... Sad
My boost 1.5 bar
Any ideas, friends?
Help! Head gasket for Pinto... Fd80b5c7d060fe3bmed
combatkit
Antal inlägg : 105
Namn : Daniell Toft
Från : Norge
Registration date : 08-06-24
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 19:09
turbo?
what type of headbolts are you using?
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 19:49
combatkit skrev:
turbo?
Stock... Sad
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 19:53
What degrees on the ignition on 1.5bar?
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 20:02
For beginning I created this map
Help! Head gasket for Pinto... C9fb85b86aceef3emed
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 20:09
what is this? Do you use some kind of piggyback?
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 20:19
Yes Smile Piggyback: ECU Master Smile
The creator of this piggiback is in the process of writing the new firmware "stand alone fuel". It's will be completely independent control of fuel dose Smile
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 20:34
And what is the standard ignition degress? Hade you checked the ignition timing? I think the gasket failed because of knocking
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 21:20
Sorry I did not write to the map legend: -1 = -1 degree.
I set the ignition at about "0". Maybe you're right, because I heard a knock at 4000RPM, when I tuned fuel map...
I made a mistake, because the head could not be compensated Sad
Is the spark plugs NGK AP7FS are good? Or better AP8FS ?
Does std Cosworth gasket will work at 1.5 bar of boost?
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 21:35
Yes i know, but do you know what the standard ecu degrees is?. if it 30 at 4000 rpm and 1bar and you lower 8 degrees you have 22 and with stock compression it might be to high
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 21:49
I dont know Sad I have ECU from Sierra Is thats all what I know Sad but I understand what you mean.
I think that in 4000 was about 1.5 bar... What should be more or less ignition advance?
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 21:52
Hard to say, try lowering 5 degrees
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 22:03
Ok, but std Cosworth gasket is not too weak for such a big boost?
Can you recommend me some gasket?
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 22:08
no it´s not. But you need a really good map to make it hold
Kriss Poland
Kriss Poland
Antal inlägg : 35
Namn : Krzysiek
Från : Poland
Kör : Ford Sierra
InläggRubrik: Sv: Help! Head gasket for Pinto...   Help! Head gasket for Pinto... Icon_minitimesön 20 jun 2010, 22:22
Thanks a lot! I really like your projects and very often I look at your forum. I learned a lot here and many of the ideas I used.
I love Ford just like you Wink
Thanks for all, we will be in touch Wink
/Kriss.
