 carbed pinto turbo
2 posters
DD
Antal inlägg : 2
Namn : Martijn
Från : ned
Kör : ned
Registration date : 10-05-04
carbed pinto turbo Empty
InläggRubrik: carbed pinto turbo   carbed pinto turbo Icon_minitimeons 12 maj 2010, 10:18
Hi there,
I'm from the netherlands and the proud owner of a capri III 1600. Now I wanted to be different and instead of tuning the engine with carbs I wanted turbo power.
Because EFI pinto's cost silly money, 400 euro's is pretty common around here, I desided to stay on carbs. the 1600 is the prototype engine just to get all the parts in the right place and have a decent base map for the ignition system. After that I will drop in a 2 liter that I got cheap.
The car is a budget build and therefore the progress is slow. the turbo components are from a renault 5 gtt. For now the car runs on with the standard dizzy but in the futere I want to go MegaJolt.
I hope to find here some people who are also using a carb on a turbo conversion.
carbed pinto turbo 001
F20A2-T
F20A2-T
Antal inlägg : 35
Namn : Pjotr
Från : The Netherlands
Kör : Accord / RX-7
Registration date : 07-12-01
InläggRubrik: Sv: carbed pinto turbo   carbed pinto turbo Icon_minitimemån 17 maj 2010, 22:55
Hi Martijn,
I tried the same thing as you did only on a 2.0 honda.
Better get a Weber 32/36 DGEV or a 34/34 DGAS.
They are better then the 5gtt carb. You're going to choke this engine with this r5 carb.
If you're going to stay carb, get a good rising rate (1:1) FPR (brandstofdruk regelaar) adjustable from 2 to ± 30 psi. (mallory 4309 or malpassi) And a pump to keep up with this pressure and demand.
If you're getting in to boost you need to add fuelpressure.
Your stock Fuelpressure is ± 3-4psi. If your boostpressure is 10 psi, you need 13-14psi fuelpressure when in full-boost.
Make sure you pull some timing wen going into boost.
PS
Just sold a complete CapriIII with 2.0i Pinto 5-speed for ± € 850
If you have any more question, you can PM me in dutch...
Succes,
Pjotr
carbed pinto turbo
» turbo technics pinto turbo manifold
» turbo pinto
» Pinto Turbo uk
» 2.3 pinto turbo
» About the Pinto turbo conversion
