 24V Turbo..... Injectors
Damocos
Antal inlägg : 25
Namn : Damian
Från : Kent England
Kör : Sierra Saff 24v
Registration date : 10-01-21
24V Turbo..... Injectors Empty
InläggRubrik: 24V Turbo..... Injectors   24V Turbo..... Injectors Icon_minitimefre 07 maj 2010, 08:19
Im trying to source some bigger injectors for my 24v turbo, problem is that they are side feed ones Neutral I am going to be running an Emerald K6 ecu and the guys there said i should run some 440cc subaru injectors. Now will these be enough for me? Or would i need bigger cc? Going to be running approx 10psi so are these going to be enough or will they be maxed out 24V Turbo..... Injectors Kopfkrat
InläggRubrik: Sv: 24V Turbo..... Injectors   24V Turbo..... Injectors Icon_minitimefre 07 maj 2010, 08:47
Six 440cc injectors can handle around 440hp. 10psi on a 24valve is around 350hp so it will do
InläggRubrik: Sv: 24V Turbo..... Injectors   24V Turbo..... Injectors Icon_minitimefre 01 okt 2010, 19:46
This might help you out. Another guy, "Tobbe H" at the forum made this post:
http://skogenracing.editboard.com/projekt-forum-f10/tobbe-h-granada-40-24v-cosworth-ute-pa-gatan-t353-90.htm#21939
(I translated it for you so you can understand it)
Tobbe H skrev:
Those sitting on the BOB is possible to do so on, I'm certain that there is several ford injectors which this can be made on, would guess that the 16v engine have similar possibility to upgrade the injectors.
It is a welded sheet metal on the top of the injector with two small holes in order to reduce the flow and to get a spray for each channel... Use a grinder to remove the weld and remove the plate and you will have a larger hole behind....... Now it is flowing 600cc/min and you have only one injector pattern...
24V Turbo..... Injectors 100_4023
24V Turbo..... Injectors 100_4028
Hope this will help you.
InläggRubrik: Sv: 24V Turbo..... Injectors   24V Turbo..... Injectors Icon_minitimefre 01 okt 2010, 19:51
Remember that the HP output "Mikael" made is calculated on unleaded fuel, with ethanol based fuel you will need much bigger injectors!
