 2.9 turbo Oil feed location?
Terry Tibbs
Terry Tibbs
Antal inlägg : 9
Namn : Nigel
Från : England
Kör : 86,2.8 twin turbo sierra kombi
Registration date : 09-09-21
2.9 turbo Oil feed location? Empty
InläggRubrik: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimeons 24 mar 2010, 22:33
A few Q's as i am about to get started on the build,
Where do i drill and tap the turbo oil feed?
Will megasquirt v3 run all (imp) injectors?
I am using a late non afm engine, will this give me any issues with setting up megasquit?
and finally, here in the uk we call the 2.9 engine a cologne, Are they known as cologne engines anywhere else?
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
Kör : Scorpio 2.9 12V Ghia, Sierra pinto EFI,
Registration date : 08-09-30
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimetor 25 mar 2010, 04:57
This is the engine's left side and on the left of the picture there is the oil hose.
2.9 turbo Oil feed location? 34960909
You need to put an Y pipe there to feed the turbo and keep the oil hose. Your engine is great for MS. And at here hungary we also call it cologne.
And I think MS will handle all injectors.
Användarens profil http://www.sierracorner.net/
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimetor 25 mar 2010, 06:49
Here in sweden we say cologne also.
MS can handle low impedance but it can generate electrical disturbance or whats it called
Pere
Antal inlägg : 5
Namn : Petar
Från : Perkovic
Kör : kor is?
Registration date : 10-04-02
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimefre 02 apr 2010, 12:03
then vems is better? or...?something else?
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimefre 02 apr 2010, 19:51
Vems is even worse when it comes to low impedance
Pere
Antal inlägg : 5
Namn : Petar
Från : Perkovic
Kör : kor is?
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimefre 02 apr 2010, 23:43
what u have?
InläggRubrik: Sv: 2.9 turbo Oil feed location?   2.9 turbo Oil feed location? Icon_minitimefre 02 apr 2010, 23:55
Megasquirt.
If you want to use lowimpedance use 25watt resistors, aim at 10ohm or somehting like that
