 manifold
rich123
Antal inlägg : 87
Namn : richard
Från : uk
Kör : 3.1 twinturbo saph rwd
Registration date : 09-03-22
manifold Empty
InläggRubrik: manifold   manifold Icon_minitimetor 18 mar 2010, 21:30
hay up i have a t3/t04e good for 500bh just wonderd what size piping to use for the joining manifolds
thx rich
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimetor 18 mar 2010, 21:48
That turbo will not do on a V6 engine, to small turbinhouse..
I use 42mm on the manifolds and 48mm on the joining pipe
rich123
Antal inlägg : 87
Namn : richard
Från : uk
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimetor 18 mar 2010, 23:19
what size turbo should i run this i have has a 2.75 inlet and a 2.25 oulet
rich123
Antal inlägg : 87
Namn : richard
Från : uk
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimetor 18 mar 2010, 23:20
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimefre 19 mar 2010, 01:03
That is like 70.5(?)mm inlet and 56? mm out i think you should go up to at least 80 - 100 mm inlet (3,10 - 4,0) and out something likely out.
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimefre 19 mar 2010, 06:48
They don´t have the right sizes but you need a turbo in this size: Garrett GT32, Garret GT37, Garret GT40, Holset HX34, Holset HX40.
On the exhaust side just over 400hp 3.0" will do but 3.5" is better.
Air inlet is depending on the turbos inlet, The air outlet works with 2.25-3", use the pipe size that the turbo has
rich123
Antal inlägg : 87
Namn : richard
Från : uk
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimefre 19 mar 2010, 08:46
how about a kkk 27 turbo will that do the job?
manifold Empty
InläggRubrik: Sv: manifold   manifold Icon_minitimefre 19 mar 2010, 09:15
Yes but is limited to 400-450hp
manifold Empty
manifold
