| gearbox? | |
rich123 Skogenracing Medium
Antal inlägg : 87 Age : 47 Namn : richard Från : uk Kör : 3.1 twinturbo saph rwd Registration date : 09-03-22
| Rubrik: gearbox? sön 24 jan 2010, 09:43 | |
| hi mikael hows things going long time no speak ,well the car is all running and mapped running now just wonderd you run a mt75 gearbox in yours is that a 2wd or a 4wd box turned in to a 2wd thx rich p.s ill send some vidoes over to ya soon | |
| Rubrik: Sv: gearbox? sön 24 jan 2010, 11:44 | |
| Here in sweden MT75 is standard behind a 2wd 2.9 cologne. It´s actually a common gearbox | |
| Rubrik: Sv: gearbox? sön 24 jan 2010, 16:49 | |
| how much can u get 1 and can u post 1 to the uk | |
| Rubrik: Sv: gearbox? sön 24 jan 2010, 16:57 | |
| ouch i don´t think it will be cheap to post one to the uk | |
| Rubrik: Sv: gearbox? sön 24 jan 2010, 17:08 | |
| lol we have to build them here pain in the arse | |
| Rubrik: Sv: gearbox? sön 24 jan 2010, 18:51 | |
Zozz Skogenracing Small
Antal inlägg : 44 Age : 39 Namn : Zoltán Från : Hungary Kör : Scorpio 2.9 12V Ghia, Sierra pinto EFI, Registration date : 08-09-30
cosworth team ruse Skogenracing Small
Antal inlägg : 26 Age : 35 Namn : daniel Från : bulgaria Kör : ford sierra 2.0 dohc Registration date : 09-11-24
| Rubrik: Sv: gearbox? tis 26 jan 2010, 11:06 | |
| i have a sierra ohc did mt 75 gear box fit to this engine or need some modifying | |
combatkit Skogenracing Large
Antal inlägg : 105 Age : 41 Namn : Daniell Toft Från : Norge Kör : Bmw E38 with S62B50 engine Registration date : 08-06-24
| Rubrik: Sv: gearbox? tis 26 jan 2010, 21:54 | |
| fits straight on, BUT, need to space out the thrust bearing 15mm... my frient cut an original T9 clutch arm and welded on the mt75 arm, and then you can use the t9 thrust bearing too se the picture. | |
| Rubrik: Sv: gearbox? | |
| gearbox? | |
