 Scottish drift Capri
Scottish drift Capri - Sida 4 Empty
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimemån 29 nov 2010, 22:39
As i said, mount the turbo on the other side (you passanger side) and reweld the inlet manifold to make it point to the other side
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
Från : Glasgow, Scotland
Kör : Capri 2.9 TT, Sierra Sapphire Cosworth
Registration date : 09-12-03
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimemån 29 nov 2010, 23:25
How laggy are these big turbo 2.9 engines?
I really would like the boost to come in as instant as possible when drifting.
When do they generally come on boost?
Andrew
Antal inlägg : 85
Namn : Andrew Dunn
Från : England
Kör : cosworth kit car
Registration date : 10-08-01
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 30 nov 2010, 02:24
Nice build, keep us updated,
I asked the same question on my topic,
believe its about 3000 rpm which isnt high, should be in that range for drifting.
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 30 nov 2010, 10:29
Awesome! I was expecting higher...
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 30 nov 2010, 11:31
Yeah looks like cutting and rewelding the manifold will be the best option to make a full mirror image or Mikael's engine bay!
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 30 nov 2010, 12:39
With the Garrett GT40 i have full boost at 4000rpm, begins to build boost @ 2500 if i remember right. 500rpm earlier with the GT37 and 1000rpm earlier with a GT32
Instant boost = small turbos = lesser power and less reabillity on the engine. The engine don´t like high torque on low revs
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimeons 01 dec 2010, 03:47
Do you know what size exhaust housing each turbo had?
Looking at a GT35 and it comes with a choice of:
0.63
0.82
1.06
What reliability issues did you find as a result of using the smaller turbos?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimeons 01 dec 2010, 12:51
Around 1 i think on my gt40. Smaller house = earlier boost but you lose power instead
To simplify you can say that the cylinder pressure are highest when the torque is highest. With standard interiors the trick is to move the torgue up a bit to spare the engine. I do this because i and don´t want to spend to much money and i can´t see the need to drift a car on 2000-3000rpm Smile. When you drift with your sierra what rpm are you using? I belive its very near revlimit? why change that?
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimeons 01 dec 2010, 13:16
Yes, I see your point. With the Sierra I'm always on the 6000RPM rev limiter during drifting!
It does have good power at lower revs, and this is useful for starting a drift or getting yourself out of trouble with instant power if a manoeuvre goes wrong (taken too tight a line in a corner).
Your specification of turbo is exactly the opposite of what usually happens in the UK! The normal route here is to use as small a turbo as possible and spend lots of money of the engine Laughing
I don't like the idea of spending lots of money if I don't have to Laughing
I'm sure the turbo suppliers will tell me to buy a smaller turbo when I start looking for one but I won't! GT40 it will have to be! Laughing
What parts failed on the engines? Was it the head gasket, or rods/pistons/crank/block?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimeons 01 dec 2010, 20:05
You will not lose power with turbo on low revs.
Head gaskets are the weak point on the cologne engine, the pistons are not the best quality.
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 02 dec 2010, 00:39
Cool, I know a supplier of custom head gaskets in case my first one fails.
Thinking of using water injection to help protect the pistons.
Do you think this would help?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 02 dec 2010, 08:49
I don´t think it will help, if you have problems with knockning maybe. But if something fails with the water pump for example you will have a nasty engine failure
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 02 dec 2010, 14:36
Might be worth trying if I can get a kit cheaply.
Anything to keep those fragile pistons a little bit cooler must be helpful Very Happy
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 02 dec 2010, 17:29
Buy a good intercooler instead. Waterinjection is something they used in the Eighties when it´s was hard to get good intercoolers
Keep it simple
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimesön 05 dec 2010, 21:40
You could try to get hold of this type of manifold
Scottish drift Capri - Sida 4 2_9_Pic1
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 07 dec 2010, 17:54
Never seen one of them before! Is that from a Cologne?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 07 dec 2010, 18:07
yes i think so
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimeons 08 dec 2010, 17:31
It is from the 2.9ers in the american cars. For more info look here!
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 09 dec 2010, 12:23
Probably be easier to just cut the European manifold rather than try and find one of the US ones! never seen one before.....
Does get me thinking though, what amount the 4.0 Cologne as used in the Explorer?
I'm sure those engines could be found cheaply. The complete cars are cheap enough!
Wonder how they would perform when turbo'd?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetor 09 dec 2010, 12:47
I don´t like it, it has a better pistons and should take more before it breaks but they answer badly on boost.
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimefre 10 dec 2010, 13:27
"answer badly on boost"? Maybe got a translation problem there!
Have you experimented with a 4.0 before?
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimefre 10 dec 2010, 19:55
It doesn´t respond well to boost, can´t explain any better.
Here you have our try http://skogenracing.editboard.com/projekt-forum-f10/crille-ford-taunus-turbo-mappad-till-09bar-t4947-735.htm
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimelör 11 dec 2010, 02:26
I've been reading the thread though a translator... Oil supply issues and the lifter design maybe being the problem?
Better with the simpler pushrod 2.9? Very Happy
The car does look awesome though! Scottish drift Capri - Sida 4 Av-26
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimelör 11 dec 2010, 08:09
Yes thats the main problems, the big dissapointment was its performance
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   Scottish drift Capri - Sida 4 Icon_minitimetis 14 dec 2010, 13:07
Some photos from today's blasting on a snowy Scottish hillside!
Scottish drift Capri - Sida 4 _DSC2563
The whole underside and various suspect areas were all blasted back to bare metal (and sometimes thin air!) in no time. Quite refreshing to see that the chassis legs and most of the floor remained intact...
Scottish drift Capri - Sida 4 _DSC2507
Scottish drift Capri - Sida 4 _DSC2494
Scottish drift Capri - Sida 4 _DSC2491
Scottish drift Capri - Sida 4 _DSC2528
The Volvo axle also got the same treatment....
Scottish drift Capri - Sida 4 _DSC2552
Scottish drift Capri - Sida 4 _DSC2556
Next step... priming and welding!
Sida 4 av 7Gå till sida : Föregående  1, 2, 3, 4, 5, 6, 7  Nästa
