 Scottish drift Capri
InläggRubrik: Sv: Scottish drift Capri   lör 12 dec 2009, 10:39
The pistons and the gaskets are weak points. The pistons works now on my engine when i got rid of my overheating problem but the gaskets don´t like 1.3bar to long.
1.1bar on stock engine works just fine
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
Från : Glasgow, Scotland
Kör : Capri 2.9 TT, Sierra Sapphire Cosworth
Registration date : 09-12-03
InläggRubrik: Sv: Scottish drift Capri   lör 12 dec 2009, 20:23
Cool, thinking of running 1bar on two T3 turbos.... should do at least 300bhp?
Are you still running standard pistons now?
Is there anywhere who sells uprated pistons or gaskets?
InläggRubrik: Sv: Scottish drift Capri   lör 12 dec 2009, 20:29
Yes thats possible. Im still running stock pistons but are in the serch for some better, don´t know of any better gaskets
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   sön 13 dec 2009, 14:53
Found these (second from the bottom). Seem to be the only ones for the 2.9... even though they seem to require modification to the heads. And expensive!
https://www.burtonpower.com/product_main.aspx?dets_product.aspx?PSet=97&sTxt=cologne%20pistons
Strange that these ones are usable on the 2.8 and 2.9? I would have assumed they would be different....
InläggRubrik: Sv: Scottish drift Capri   sön 13 dec 2009, 19:38
The only difference is the bowl, flat on 2.8 and bowl on 2.9
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   sön 27 dec 2009, 15:00
Looking to buy an intercooler.... what size are you running in the Capri Mikael?
InläggRubrik: Sv: Scottish drift Capri   sön 27 dec 2009, 15:54
Metrical
total is 630mm (cell is 450x300x76)
SmallDeree
SmallDeree
Antal inlägg : 1
Namn : Edgars
Från : Silins
Kör : Ford Sierra 2.0 No Turbo
Registration date : 09-12-28
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 00:27
Nice Car! Smile
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 13:35
thanks, will find one somewhere!
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 16:57
Sorted! Just ordered this....
Intercooler 002 (Core size 450x300x76 Overall size 630x300x76)
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 18:59
Nice Smile
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 20:18
The kit I'm getting has a pair of T2 turbos.... I am considering maybe swapping to a pair of T28s or even one T28 and one T2.
I did think a pair of T3s at first, but these will probably be a different flange fitment. Think the Nissan 200sx style T28 is the same T2 fitment and very common/cheap.
Also one big and one small may be good for a speedy spool up of the turbos?
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 20:27
Uncertein about the T2 but i think 200hp each so they are a bit small. Two T25 would work better
Dont mix turbos, it will genereate unbalance. And i still think you should get hold of one mighty turbo, its much easyier to fix the piping Smile
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 20:50
t25 from the 200sx ca18det ~250hp max 1,2bar of boost or they won't hold for long.
t28 from sr20det s14 ~300hp 1,5bar of boost max i think. But thats on the small 4cylinder engine.
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 20:56
Use the T28, they will be your best choice
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 28 dec 2009, 22:46
I would love a big single turbo but the costs I have been quoted for a custom manifold make this too expensive Sad
Maybe sometime at a later date.....
I've also committed to buying the twin turbo set up, so I may as well make the most of it..... think a pair of T28s sound like the best idea, I will look into sourcing them....
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 04 jan 2010, 14:15
When converting to Megasquirt, can you control the ignition advance/retard even though the engine is running a distributor?
I thought maybe you would need a more modern coilpack system without a distributor to successfully map the ignition?
InläggRubrik: Sv: Scottish drift Capri   mån 04 jan 2010, 21:33
No problem to control the ignition with a distributor setup!
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   mån 04 jan 2010, 22:13
Tempted to get Gotech management if my budget can strech to it....
My tuner who will set this car up prefers it to Megasquirt. But it is about £1000 in total!!!
InläggRubrik: Sv: Scottish drift Capri   mån 04 jan 2010, 22:34
Never heard of Gotech, choose a system you tuner prefers. here in sweden a Megasquirt with sensors will cost around £350
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   tis 05 jan 2010, 15:14
That's cheap! Is that one you have to build yourself? ..or is it ready assembled?
InläggRubrik: Sv: Scottish drift Capri   tis 05 jan 2010, 15:51
ready to use..
u can buy it from the states here: http://www.diyautotune.com/catalog/index.php
but we buy it from a guy here in sweden that assamble them..
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   ons 06 jan 2010, 14:41
Looks good, will investigate further...
InläggRubrik: Sv: Scottish drift Capri   ons 06 jan 2010, 15:30
There are one in the uk that sales Megasquirt also http://www.extraefi.co.uk/
Ade
Ade
Antal inlägg : 113
Namn : Ade Brannan
InläggRubrik: Sv: Scottish drift Capri   tor 07 jan 2010, 01:44
Megasquirt is looking increasingly tempting!
Do you guys have maps for the turbo'd 2.9 I could use? Even though I'll be using a twin setup I'm sure it would be a good starting point Very Happy
Sida 2 av 7Gå till sida : Föregående  1, 2, 3, 4, 5, 6, 7  Nästa
