 Sköld - Capri **Masken** MMS bombning sid 15-16
capri
Antal inlägg : 61
Namn : Mattias
Kör : Impala Cab LT1 383 Turbo, Ford Capri 2,9i Turbo, Honda Superblackbird, Yamaha Rx1 Mtn Turbo m.m.
Registration date : 07-10-31
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 15:13
deshi skrev:
Hi sorry bout english but i dont speak your language. I have a capri too and i adapted sierra track control arm and rack ftoo, i actually reversed them and the connecting rod is infrot as in capri . This i also adapted suspension form rs 2000 escort mk 5, well it`s a lot better than the original one , and i dont need spacers for the wheels
if you re interested bout this i can show you the other things
Interesting,have you measured the wheelangles with the Sierra/ Escort parts mounted?. Have you got any more pictures?.
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
Registration date : 10-05-31
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 18:35
camber is 3 degrees when the car and caster is 5 ...... as far i can remember Smile i started today my thread here in english section and i will make photos this weekend , and will show what i mean ... hm didnt mensioned that i also use a hub carriers from sierra.
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
Registration date : 08-08-17
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 18:41
hmm sounds like you got some sweet wheel angles,please take a lot of photos for us Smile
deshi
Antal inlägg : 20
Namn : Geo
Från : Ivanov
Kör : slavov
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 18:57
well i`l be happy to help Smile at the end of the weekend you`l have the pictures. Smile
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 19:35
Sköld skrev:
Jaha du har man fått i Orginal snurrar lite provesoriskt då och kan konstatera att jag behöver mjukare fjädrar fram, det sitter 225lbs på nu och det är ganska stumt enda som fjärar är 13" hjulen Very Happy
Om det finns tid i morgn ska jag prova 200lbs men har även ett par 140lbs påväg hem från England.
Motorn ska även sättas fast ordentligt.
Söker även efter en lite nya pinto med 205 block och säten i toppen någon som har ståendes får ni gärna hojta till då jag har massa turbo prylar som bara sammlar damm nu Crying or Very sad
Några minuter senare
Tadaa! växellådsbalken sitter inte fast därför motorn lutar.
hahahaha du får ju plats med ett gäng motorer till Smile
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 22 jun 2010, 21:56
Ja du har ju hur mkt plats som helst Smile
"host v6/v8 host"
Bra blir det iaf Smile
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 23 jun 2010, 04:00
mjo det finns gott om plats över Laughing
Blir en v8 till vintern om ja får behålla jobbet så mycke kan jag ju säga ialla fall rabbit
bonusbild..
Idag har det hänt massor! tror vi har lyckats kapa bort nästan all den rosten som var kvar (halva bakvagnen) så till veckan blir det till att bygga nya rambalkar och fjäderinfästningar då dom gammla var i perforerad kexchoklad.
Golv med div tidigare lagningar
Börjat på ny innerskärmar med,dom gammla var för små och lite för luftiga för min smak
Rambalk + fäste för bladfjäder. Notera golvet man kan se genom balken
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 30 jun 2010, 18:42
Åker iväg och hämtar en till bred Capri på Fredag blir att ta lite delar ifrån och såsmåningom bygga klart om det blir tid över
Bilder kommer när den står i garaget! bounce
Antal inlägg : 374
Från : Finland, larsmo
Kör : Mercedes 300D W123
Registration date : 08-03-08
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 30 jun 2010, 19:37
Nej, ingen v8 snälla Smile
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 30 jun 2010, 19:41
va är det för fel på 8or nu då?... men nej det blir ingen 8 än
https://www.youtube.com/watch?v=xNPgLg35I40&playnext_from=TL&videos=lmcRQy7Smo4 vill ha drunken
Antal inlägg : 374
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 30 jun 2010, 20:43
Vem vill ha en motor med stötstänger på 5 liter med 150 hästar? finns bättre motorer Smile
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 30 jun 2010, 20:46
5 liter 16 stänger och 350hk "orginal" är kul och billigt
sen finns det ju förvisso modernare v8r men att bygga på något med 4 kamaxlar och 32 ventiler känns inte så ekonomiskt,kan bli äckligt dyrt om det händer något då.
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tor 01 jul 2010, 07:26
Turbo, kamaxel, snygga till topparna, kolvar och stakar samt lite pyssel så har man 700-800hk på en halvmiss Smile
Antal inlägg : 374
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tor 01 jul 2010, 13:18
Syftade mest på original utförande Smile
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tor 01 jul 2010, 14:09
skulle aldrig komma på idén att stoppa i en orginal v8 i caprin,är så gott som gratis att trimma och alla jobb kan jag göra på jobbet tongue
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   lör 03 jul 2010, 01:29
Ojj Ojj vilket äventry men efter 12 av 24 timmar på dygnet i bil är nu Caprin hemma bara slängt av allt nere vid garaget bättre bilder kommer imorgon om jag får ork för nu ska jag sova!
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   lör 03 jul 2010, 10:52
Vilka däck! Very Happy
Antal inlägg : 376
Namn : Robin
Från : Åland Jomala
Kör : BMW E30 328 // M52B28
Registration date : 08-11-23
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   lör 03 jul 2010, 12:00
Kunde nästan gissa att det var denna du skulle hämta =) http://forum.savarturbo.se/viewtopic.php?t=47269
volvokng
Antal inlägg : 528
Namn : johan dahlqvist
Från : kungsgården
Registration date : 09-10-19
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   lör 03 jul 2010, 19:53
vilken fräning är nästan så en anna skulle kunna tänka sig en sån där ju dom är bra läcker caprin
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   mån 05 jul 2010, 21:24
Jaha då var det dags igen!
Har fortfarande inte lyckats skaffa några profiler till att bygga rambalk ibak eller fastsättning till stolarna men efter en temligen onykter helg var det idag dags att få lite gjort i alla fall.
Har slängt upp bakvagnen igen för att kolla lite hur hjulen hammnar,tänkte flytta upp rambalken ca 30mm fram och 45bak sen när jag åndå måste byta ut dom.
tänkte göra 2 hål i bakkant så man kan flytta fjädrarna upp och ner efter behag.
Aja i vilket fall så tog det ett bra tag att få upp den igen,sen bytta jag däck runt om så nu är det 245/55/14 fram och 265/55/14 bak. Basketball
Har även börjat att flytta äver inredning från den andra Caprin för att se så alla fästen och sånt finns och det är några till baksätet som saknas,annars ser det ut att bli riktigt bra baksätet i caprin är riktigt kungligt att sitta i king
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 06 jul 2010, 19:33
Vart lite gjort idag med, kvar att göra innan jag ser vart den bär av är slänga på 2" sänkblocken får ta det någon dag när jag får tid lust och ork
Skulle behöva åka och köpa mer grundfärg då den gröna är gräslig!
kangas
Antal inlägg : 12
Namn : erik kangas
Från : Degerfors
Kör : Volvo s80t6 bmw 318i-85 Volvo 245Glt
Registration date : 08-08-19
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   fre 09 jul 2010, 11:06
Ser ju skit häftig ut nu =)
Sköld
Antal inlägg : 442
Namn : Andreas
Från : Degerfors
Kör : tom kaross
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tor 05 aug 2010, 09:58
Här har det inte hänt mycke på ett tag dels av att jag jobbat som en tok men sen så är ju även Top Doorslammer serien i full gång och det blir inte många helger lediga.
Men nu var jag i alla fall nere en sväng i går och satta fast och höjde upp bakaxeln,fick även svetsa dit lite fästen som saknades för instrumentbrädan.
Känns ganska skönt att det börjar likna en bil igen, så nu väntar jag bara på lönen så jag kan beställa dom sista grejerna innan det blir att åka till Bes och se deras glada miner.
Oh well over and out Gardermoen here we go!
Hellbergarn
Antal inlägg : 3
Namn : Peter
Från : Örebro
Kör : Opel Rekord '78, Cadillac '69, 240 '78 ,Skoda pickis '98
Registration date : 10-08-10
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   tis 10 aug 2010, 22:40
Du håller dig till jänke koncepten med bladfjädrar och vinkel8. Skulle inte du bygga 4länk? Razz
maranello
Antal inlägg : 187
Namn : jocke
Från : örebro
Kör : s10 sportside / sierra pinto
Registration date : 08-08-27
InläggRubrik: Sv: Sköld - Capri **Masken** MMS bombning sid 15-16   ons 11 aug 2010, 20:17
Tycker det ser bra ut, är dock lite skeptisk till all denna byggskum. Spricker det inte i framtiden tror du?
men det blir grymt fint iallafall, kämpa på bara!
Användarens profil http://www.jnpp.se
Sida 5 av 10Gå till sida : Föregående  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Nästa
