 Going to give this a try...
capri2lover
Antal inlägg : 3
Namn : James
Från : The States!
Kör : 1977 capri 2.9L
Registration date : 09-08-21
Going to give this a try... Empty
InläggRubrik: Going to give this a try...   Going to give this a try... Icon_minitimefre 21 aug 2009, 18:52
Hello all! I have a 1977 capri mk2 with a 2.9l scorpio motor. I would love to get some information for parts and suppliers. I have an 8" ford posi differential and I am currently looking for a transmission that will hold the power of turbo when i get one.
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimefre 21 aug 2009, 23:16
I use a bmw gearbox in my Capri but you are american? Borg Warner T5 from a mustang would work i think. Must be easy to get hold on i the states
capri2lover
Antal inlägg : 3
Namn : James
Från : The States!
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimelör 22 aug 2009, 03:03
I noticed that you said you used two of the same side exhaust manifolds for your turbo setup. I am able to get a 5 speed gearbox from a scorpio which is like a sierra xr4x4 but I think that it is a type 9 box. Stock motor with no turbo would be fine I'm sure. What does an MT-75 come off of? Is that a 5 speed? And where did you mount your fuel pump?
I have read in past posts all over this forum that english is not your native language. I use google translate from swedish to english and it works pretty good for me so if there is any communication problems let me know, swedish or english.
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimelör 22 aug 2009, 08:41
Mikael has mounted the fuelpump inside the fuel tank.
Welcome to this site
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimelör 22 aug 2009, 10:45
MT-75 gearbox sits behind every 2.9 here in sweden, it´s stronger than the type 9 gearbox.
We have done some different exhast manifold for the 2.9. You will se pics on them in kryckans two sierra threads in projekt. and i have two threads, the old capri thread and the sierra 2.9 thread
capri2lover
Antal inlägg : 3
Namn : James
Från : The States!
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimelör 22 aug 2009, 21:06
I have some exhaust manifold flanges I can build, but as far as manifolds to start with and modify, they are impossible to find. Do you guys do fabrication and sell parts?
And thank you for the greeting!
James
InläggRubrik: Sv: Going to give this a try...   Going to give this a try... Icon_minitimelör 22 aug 2009, 22:07
We don´t manufacture and sell. But just make flanges and construct you own manifolds, it´s no big deal actually. We use standard tubings from warmwater systems
Going to give this a try... Qsqfzs
Going to give this a try... 1256zi1
Going to give this a try... 55jqjo
Going to give this a try... 8xliqb
Going to give this a try... Mmcva8
Going to give this a try... 2w3p1s4
Going to give this a try... 2drtffl
Going to give this a try... 214a2k3
Going to give this a try... V8b2t
Capri thread -> http://skogenracing.editboard.com/projekt-forum-f10/mikael-ford-capri-v6-gt40-turbo-borjar-om-pa-ny-trad-t2804.htm
