 Latvian pinto turbo
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
Kör : Sierra 2.0 DOHC
Registration date : 09-05-19
Latvian pinto turbo Empty
InläggRubrik: Latvian pinto turbo   Latvian pinto turbo Icon_minitimetis 18 aug 2009, 00:26
Hy, Im form Latvia.
Me and my friend saw your turbo sierras long ago, but this summer we decided we needed one too Very Happy
So we found the donor car (2.0 is sierra) and started the project. The goal was to buy and build the car for about 400$, but we ended up spending more like 600$.
Current setup:
Turbo form Nissan s13 (Garrett t25), boost 0,7 bar
Intercooler from Saab 9000 2.0 turbo
350cc injectors form Saab.
Running on 98 octane fuel
Latvian pinto turbo 20081130030
Latvian pinto turbo 20081130031
Latvian pinto turbo 20081130037
Latvian pinto turbo 20081130028
Now the engine is running, but we are having some problems with it. You can hear it in the video (the car drives terrible when off boost). Could it be the fuel mixture being too rich?
http://illiweb.com/fa/pbucket.gif
Also one more question: can I run on E85 with stock engine and fuel system or do I need to modify something.
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimetis 18 aug 2009, 09:15
Yes it´s running to rich. Try change to a bigger airmeter or just modifera the one you got with a harder spring so it´s wont open så easy
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimetis 18 aug 2009, 14:59
Thanks for the advice, did it today.
One more question does it matter that the stock injectors were 16 ohm, but the new Saab injectors are only 12 ohm? cheers
Can I run on E85 without modifying anything?
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimetis 18 aug 2009, 15:43
No it don´t matter with that differance.
E85 demands 30-40% more fuel and i suspect you injectors will be a bit small
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimeons 19 aug 2009, 10:30
Ok thanks.
Will keep you updated, I plan to finish my exhaust system tomorrow.
combatkit
Antal inlägg : 105
Namn : Daniell Toft
Från : Norge
Registration date : 08-06-24
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimeons 28 okt 2009, 14:19
or drill an 6mm holl in the maf flap Wink
thats help much
Latvian pinto turbo Beggelmm
Boby
Antal inlägg : 15
Namn : Toms
Från : Klame
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimelör 27 feb 2010, 19:56
During this winter I have managed to do some upgrades:
I have bought, rebored, redecked and honed an Pinto 185 block (overbored to 90.0 mm)
Latvian pinto turbo DSC_0054
Bought more durable pistons from Saab 9000 2.3 Turbo (they do fit on stock Pinto cranks)
Latvian pinto turbo DSC_0057
Got my crankshaft grinded to 0,25mm
Latvian pinto turbo DSC_0168
Bough all of the necesarry seals for the engine.
The next step is to assamble the engine and order my Megasquirt.
InläggRubrik: Sv: Latvian pinto turbo   Latvian pinto turbo Icon_minitimelör 27 feb 2010, 20:06
intresting that you use saab parts.
Latvian pinto turbo Whistlin
Latvian pinto turbo
