 megasquirt
rich123
Antal inlägg : 87
Namn : richard
Från : uk
Kör : 3.1 twinturbo saph rwd
Registration date : 09-03-22
megasquirt - Sida 4 Empty
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimemån 25 maj 2009, 13:10
right i got it Smile so i just need to adjust the req fuel by small amounts e.g
from 4.6 to 4.2
then adjust the ve table if it requires it
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimemån 25 maj 2009, 15:50
hay there mikael i dont suppose there is any chance you could send me your mapp again i just cant get the car started again i put everything back to the way it was on the mapp but still nothing
many thanks rich
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimemån 25 maj 2009, 16:45
Here you have, i put together a couple of starting mapps, the ignition table is kind och low on all but it´s for safety reason so you need to adjust it somewhat when you got it running good
http://skogenracing.myftp.org/forum/Megasquirt/Mappar/Startmapp_TFI_6cyl.msq
You always need to adjust the VE table but you need to adjust the req fuel so close you can
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimemån 25 maj 2009, 17:59
thanks for that mikael got it running again Smile now ill be more carefull what i change on it:)
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 10:35
hay up mikael how it going,well i think im getting the hang of this mapping buisness lol
i also relized that i was still running my standerd injectors they are only 160 cc or so so ive just changed them over and ill see what diffrence i get
thanks rich.
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 14:26
no nothing i cant get it started at all now Sad i was wondering u sent me a safe start up mapp which 1 is it
thx rich
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 15:43
Did you use the startmapp_TFI_6cyl.msq that i linked to i bit up in this thread? it should work directly with 350cc injectors with 3bar fuelpressuare
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 16:56
yes thats the 1 i used i go to start it and it starts then cuts off and fluds the engine
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 17:07
i was just thinking are you using a standerd fuel reg
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 18:19
Yes, standard fuelregulator is more than enough
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 18:57
do u think i should try putting the req fuel down to like 200 cc injectors
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 19:08
I think you should try some different values until it runs
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 19:10
values in the ve table or the req fuel
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 19:17
The req fuel of course!
Í can´t explain this no more, this is basic if you dont understand how this system works then read the read the manual at least 10 times, if you still don´t understand, read it 10 times more. And if you still don´t understand, pay somebody to tune the engine for you Smile
http://www.msextra.com/manuals/MS_Extra_Manual_Index.htm#tune
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetor 28 maj 2009, 21:16
no probs lol:) i think i got it now ive just turned the idle values down and i seem to be making some progress Smile
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimelör 30 maj 2009, 14:49
hay up mikael going well now all is ok aprt from i cant seem to get my idle down but i will figure that out Smile turned all my fueling down a bit now ticking over well now just shes sitting at around 13000 revs
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimelör 30 maj 2009, 15:59
Remove the iac contact and se if it gets lower
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimelör 30 maj 2009, 16:14
yea it does a lot lower
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimesön 07 jun 2009, 11:39
hi mikael just wondering are you using a pwm valve or a on/off switch i still cant seem to get my idle down,the only time i can get it down is when i unplug my idle valve then it goes down to 600 rpm
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimesön 07 jun 2009, 17:17
I dont´s use idle valve. I adjust the idle mechanically
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimesön 07 jun 2009, 18:20
ah thats were im going wrong great ok that makes sense thx mikael for your help hopefully i should be ok now Smile
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
Registration date : 07-12-17
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetis 16 jun 2009, 17:40
Doesnt fords have EFI systems? my 2.9 does:/
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimetis 16 jun 2009, 18:38
yes they do but i put a stand alone management in
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimefre 14 aug 2009, 18:51
hi mickael sorry ive not been been madness at work i was wondering what injectors are you running and what are they off
many thanks rich
InläggRubrik: Sv: megasquirt   megasquirt - Sida 4 Icon_minitimefre 14 aug 2009, 18:53
Bosch 350cc @ 3bar in the Sierra. Mounted in Saab 900 Turbo as standard
megasquirt
Sida 4 av 6Gå till sida : Föregående  1, 2, 3, 4, 5, 6  Nästa
