| megasquirt | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 10:32 | |
| You just open the file when you are connected to the Megasquirt and it will will ask if you want to burn the file, do that and wait a minute. I looked at the msq you gave me att mail and it´s has the wrong mapsensor, one squirt instead of two and trigger angle addition. I suggest you use my map instead. | |
rich123 Skogenracing Medium
Antal inlägg : 87 Age : 47 Namn : richard Från : uk Kör : 3.1 twinturbo saph rwd Registration date : 09-03-22
| Rubrik: Sv: megasquirt lör 11 apr 2009, 11:23 | |
| ah i c so i can just burn the map you sent me stright on to the ecu ok
do i need to save the map or do anything before it askes me to burn it | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 17:57 | |
| Just burn the map. Its the best way | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 19:01 | |
| ok got all that done but im still having problems with starting i just cant seem to get a pulse from the injectors does my tfi module controll anything to do with fueling or pulse width | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 19:08 | |
| Yes, you must have rpm. Around 100-200 att cranking speed | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 19:16 | |
| ah i c so do i put this in to the ecu | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 19:19 | |
| just looked its set to 300 i bet im still having problems with my wiring on the tfi module | |
| Rubrik: Sv: megasquirt lör 11 apr 2009, 21:04 | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 11:52 | |
| ive been playing around again and what i have found is that when i turn the engine over there is no pulse but when i turn it off i get 1 pulse any ideas on that | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 16:47 | |
| check so that the injectors have 12+ when running on the starter | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 16:56 | |
| yea i have i even tryed putting the 12v direct from the battery but still did the same nothing on turning over and 1 squirt when turning off | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:00 | |
| And you have burned my mapp? Check your TPS så it´s not in floodclear position. If you connect the cables wrong it will belive it´s full throttle | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:19 | |
| yes i burned your map on clear the tps for flood clear is that what your on about | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:27 | |
| ok the cranking rpm is at 300 and the tps value for flood clear is at 178 | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:42 | |
| If it dont show flood clear and the injectors don´t open, i think you have messed upp the wiring or burnt the box | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:47 | |
| i dont get how everything else is working normaly if you get spark you get fuel and also why am i getting 1 squirt when i turn it off | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:49 | |
| were is the flood clear in megatune ill double check | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 17:56 | |
| if i had burnt the box would the stim show it up as thats working all ok when connected to the stim | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 18:15 | |
| the floodclear goes in when you are cranking at full throttle, a small sign lights upp in megatune showing that | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 18:17 | |
| does it come on at the bottom of megatune were the fuel pump on/off is | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 18:18 | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 18:25 | |
| all i have at the bottom is
fuel pump on/off fan/w injoff nos/w inj off output1/boost cont output2 off fan/output4on launch off no knock nos/tables off
is it 1 of those that flash up | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 19:42 | |
| ok just tested the flood clear when i turn the engine over the flood light stays on untill i put my foot to the floor then it goes off is this right | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 22:33 | |
| no this is not right, you have probly connected the tps wrong, you can test this by calibration the TPS under the tools meny Closed throttle ADC count should be around 10-30 Full throttle ADC count should be around 200 Here is pic on how to wire the 2.9 TPS VREF = pin 26 Signal = pin 22 Jord = ground | |
| Rubrik: Sv: megasquirt sön 12 apr 2009, 22:40 | |
| ah i c great do you think this would stop my injectors from pulsing | |
| Rubrik: Sv: megasquirt | |
| megasquirt | |
