 megasquirt
Gå till sida : Föregående  1, 2, 3, 4, 5, 6
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
Registration date : 07-12-17
megasquirt - Sida 6 Empty
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 sep 2009, 14:14
there are different versions of ms1...what should I choose and what is extra 029y4?
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 sep 2009, 16:47
show me the different versions then.
029y2 is extra code, to controll the igntion and so on
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 sep 2009, 16:57
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 sep 2009, 16:58
I use 3.0 works fine for me, but we buy them from a person here in sweden that modifiy them for our spec
http://www.blocket.se/vi/21630506.htm
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 06 okt 2009, 18:23
where can I get this megatune program ?
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 06 okt 2009, 18:35
pluto
Antal inlägg : 6
Namn : pluto
Från : Estonia
Kör : sierra
Registration date : 09-02-02
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetor 15 okt 2009, 19:59
Hi Mikael,
I got my engine run now with your start-up map. Thanks a lot for that!
I was wondering if u had more maps for 350 cc wchich I could use for adjustable? I use 350 cc and K27 turbo so I'd be greatful if U could give me a consistent map.
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetor 15 okt 2009, 20:06
Diskovod
Antal inlägg : 2
Namn : Alex
Från : St. Petersburg, Russia
Kör : '72 Taunus, '84 Celica (4A-G 16V N/A)
Registration date : 09-12-13
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimesön 13 dec 2009, 13:40
Hi Mikael!
Are the swedish assembled MegaSquirt V3 boards intended to use only with turbocharging? Or it can be used with N/A ITB setup as well?
Thank you!
p.s. Can MS1 maps be adjusted to MS2 or they are completely different?
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimesön 13 dec 2009, 19:40
It works fine on N/A setups to.
It should be possible yes to use the vex filens on a MS2
Diskovod
Antal inlägg : 2
Namn : Alex
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 dec 2009, 01:15
Thank you!
So that swedish assembled MS is a kind of V3, while the ones on DIYautotune are V1/V2s and V3 is respectably better than the previous, right? So I obviously should get MS V3 for my N/A purpose to get the best working MS?
InläggRubrik: Sv: megasquirt   megasquirt - Sida 6 Icon_minitimetis 15 dec 2009, 06:48
It´s a MS1 V3.0 that is bought from DIYautotune and assembled here i sweden and modified to the spec the buyer needs
megasquirt
Sida 6 av 6Gå till sida : Föregående  1, 2, 3, 4, 5, 6
