 megasquirt
rich123
Antal inlägg : 87
Namn : richard
Från : uk
Kör : 3.1 twinturbo saph rwd
Registration date : 09-03-22
megasquirt - Sida 5 Empty
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimefre 14 aug 2009, 19:01
thanks mikael im not sure is the injectors i have are too big they are 480cc and not sure if the ms 1 can take the resaloution for them so i might have to get some smaller 1's
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimefre 14 aug 2009, 19:30
No it´s no problem, but you need to adjust the map when you are using bigger injectors than the map is made for
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimefre 14 aug 2009, 19:34
ah i c ok no probs car is all running ok now got it mot'ed the other day and its running well pulled well i just need to tweak the mapp as im still running the start mapp Smile
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 12:57
hi mikeal just wonderd do you have a mapp for the m/s 2 i am upgrading to ms 2 soon or will the mapp for the ms 1 work on the ms2
thx rich
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:04
Why uppgrade? MS1 works fine. I don´t have a mapp för MS2, you have to construct your own now
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:45
you can controll the fueling a lot better were the ms 1 you can only go from 0.3.down to 0.2 were the ms2 you can go from 0.3 down to 0.299 i find its a lot more precise plus i cant get the car from overfueiling when i put the bigger injectors in
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:51
If you cant get the car to run good with MS1 than you cant get i to run much better with MS2.
I have tuned a car with 850cc injectors on a Cosworth 4cyl without to much problem.
630cc injectors on a Ford V6 is no problem, how big is yours?
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:53
mine are only 480cc but juts seems no matter what i do i cant get it to stop overfueling
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:55
Then you have a problem, and it will not matter if you change till MS2
My engine runs lambda 1 at idle with 440cc injectors and v6t46 kent cam
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 14:59
is that on the same mapp as i am running
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 16:00
ok cool before i do any upgrading i have a mate who is coming down so i will see what i can do with it Smile i have it running well on 160cc injectors so im sure i should be able to get ok with 480cc
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 17:53
I don´t remember what map i gave you
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 18:35
it was the start mapp for the 350 cc tfi any chance i get a copy of the mapp you run on your car now and ill try that Smile
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 18:46
give me you mail then
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 18:47
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 20:42
hi mikael did u get my email
thx rich
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 21:34
You got mail
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 22:14
thanks ever so much its very appreciated Smile i will try this mapp tomorrow if the weather is not raining and i will send you some video s when its going right
thanks mikael
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 22:35
what sort of boost are you running with this mapp
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 22:41
peaks 1.2bar and runs 1.1bar but have tested 1.4 and it´s works on that to, but don´t feel safe running such boost on standard compression and engine
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 22:43
thank mikael love the capri by the way its very tidy car Smile
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimesön 23 aug 2009, 22:54
Thanks Smile
rich123
Antal inlägg : 87
Namn : richard
Från : uk
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimemån 24 aug 2009, 20:48
hi mikael well its all good working great i think Smile sits at around 1000 rpm and nice and smooth i just need to set my boost up on it now and my fuel regulator and all should be ok
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
Registration date : 07-12-17
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimemån 14 sep 2009, 20:54
which version MS is it and how much does it cost when it is complete and I can just do the wiring?
Pinouts for Megasquirt in Sierra 2.9i
PIP & SPOUT is for the ignition.
PIP (MS24) is the signal that goes to TFI Ignition module pin 6
SPOUT (MS36) is the trigger that goes to TFI Ignition module pin 5
Orginal Contact -> MS Contact
Pin 25 (Brown/yellowl) -> MS20 (Air temp)
Pin 7 (Brown/Green) -> MS21 (Coolant temp)
Pin 47 (Brown/Green) -> MS22 (TPS signal)
Pin 29 (Brown/yellow) -> MS23 (Lambda)
Pin 56 (Blue/yellow) -> MS24 (PIP)
Pin 26 (Brown/black) -> MS26 (TPS Vref)
Pin 37 (black) -> MS28 (+12v)
Pin 57 (black) -> MS28 (+12v)
Pin 21 (Brown/yellow) -> MS30 (Fidle Solonoid)
Pin 22 (Blue/Red) -> MS37 (Fuelpump relay)
Pin 58 (Brown) -> MS32-MS33 (Injectors)
Pin 59 (Brown) -> MS34-MS35 (Injectors)
Pin 36 (Blue/red) -> MS36 (SPOUT)
Pin 16 (Brown) -> Earth
Pin 40 (Brown) -> Earth
Pin 46 (Brown) -> Earth
Pin 60 (Brown) -> Earth
Put the two black together and draw a smaller wire to MS28
Put the earth wires together and draw two smaller wire to MS8-9 & MS10-11
InläggRubrik: Sv: megasquirt   megasquirt - Sida 5 Icon_minitimemån 14 sep 2009, 21:23
MS1 with extra 029y4. Look at http://www.diyautotune.com/ for pricing
megasquirt
Sida 5 av 6Gå till sida : Föregående  1, 2, 3, 4, 5, 6  Nästa
