 cologne 2.9 V6 turbo questions
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
Kör : Scorpio 2.9 12V Ghia, Sierra pinto EFI,
Registration date : 08-09-30
cologne 2.9 V6 turbo questions - Sida 3 Empty
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimelör 20 jun 2009, 23:53
Can somebody describe me what is flatshift you sometime talking about?
Användarens profil http://www.sierracorner.net/
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 jun 2009, 00:02
http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#launchC
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
Registration date : 09-06-11
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 jun 2009, 21:25
Albis skrev:
cologne 2.9 V6 turbo questions - Sida 3 38187266
i have a similar turbo, but it is k25 bit smoler will it be good for 2.9?
Question
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 jun 2009, 21:30
How should we know that, you need to give us more information on wheel sizes and so on
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 28 jun 2009, 22:40
ok, one more question: are you doing something with oil presure? or it is good enoth to add turbo lubrication and oil cooling?
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimemån 29 jun 2009, 16:04
Yes it's good enough
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimemån 29 jun 2009, 16:31
looks every thing is sorted. thanks mikael
I will use 2 KKK k26 turbos on 2.4 engine will see what will hapen.
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimemån 29 jun 2009, 16:38
2 turbos is a bit silly, one large is much cooler Smile And it will get you a cleaner engine bay
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimemån 29 jun 2009, 16:50
I now that, and I whant a single turbo too, but it is too expensive for me. it is a 100 eur. projekt build from scrap Very Happy still beter then nothing. enouth to have fun.
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimetis 30 jun 2009, 23:26
Mikael what type of steel did you used for building the capri 2.9 exhaust manifold? Stainless or some regular?
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimeons 01 jul 2009, 06:46
regular
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimeons 01 jul 2009, 14:19
regular
Thank you!
Zozz
Zozz
Antal inlägg : 44
Namn : Zoltán
Från : Hungary
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimelör 18 jul 2009, 13:55
I read this at Kryckan's topic with some brutal pics of a broken engine. Can somebody tell me in english what happened with it? :
Kryckan har ju haft lite strul med lagerknack så vi beslöt oss för att byta motor, blev lite förvånade när vi såg att tråget var lite buligt och det var ett litet hål stort som en 50-öring. sen när vi lossade motorfästet så ramla en bit av motorn bort, vidare så låg det en hel hög med roliga delar i tråget, bara kika på bilderna och begrunda Smile
Liljan
Liljan
Antal inlägg : 191
Namn : Fishmaster
Kör : riktigt långsamt med Suzuki SJ413 och Lynx Skogsräv
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimelör 18 jul 2009, 20:14
In short "Kryckan has had some problems with a noisy rod-bearing so we decided to do a engine swap. We were somewhat suprised to learn that the oilpan was a bit dented and there was a hole about the size of a small coin in it. When we loosened the bolts for the engine mounts a piece of the engine fell out, furthermore there was an assortment of engine parts inhabiting the bottom of the oilpan. Just check out the pictures and ponder."
pluto
Antal inlägg : 6
Namn : pluto
Från : Estonia
Kör : sierra
Registration date : 09-02-02
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimetis 25 aug 2009, 23:23
Hi Mikael,
Inkoppling Megasquirt 1 V3.0 för Ford Sierra pinto med orginal Hallgivaren i fördelaren....
what kind of sensor do you use on v6?
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimeons 26 aug 2009, 09:18
Original Hall Sensor in the distributor works fine
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
Registration date : 07-12-17
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimelör 20 feb 2010, 15:39
i got a turbo from a bus... its turbine diameter is about 75mm and hot side housing is bigger than your GT40. Is it too big for 2.9 and your map?
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimelör 20 feb 2010, 16:49
It´s a bit big but can work. The big problem is that such a big house and turbine it will be a bit slow spooled
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 feb 2010, 20:36
Okei. I took some pics to compare with yours....is it too big? Its a Schwitzer 313951
cologne 2.9 V6 turbo questions - Sida 3 Turbo1
cologne 2.9 V6 turbo questions - Sida 3 Turbo2
cologne 2.9 V6 turbo questions - Sida 3 Turbo3
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 feb 2010, 20:45
I think it will be att bit big but it can work. very hard to tell
Tehnic
Antal inlägg : 15
Namn : Tehnic
Från : EST
Kör : SIERRA
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 feb 2010, 20:48
okei:D then must try and if No, then replace
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimesön 21 feb 2010, 20:52
Yes thats the problem, but the turbo will work thats certain but it can be necesery to adjust a bit if you want to use my Megasquirt map
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimetis 23 feb 2010, 19:40
ok hire's mine, it was realy difficult to plase it so far back. and it runs on LPG Smile cologne 2.9 V6 turbo questions - Sida 3 1266950321_15_FT669_nuotrauka0661
Albis
Antal inlägg : 16
Namn : Albis
Från : Lithuania
Kör : sierra
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimetis 23 feb 2010, 19:54
first i mede it with 2.4 v6 hire's consequences Smile cologne 2.9 V6 turbo questions - Sida 3 1266778878_15_FT669_nuotrauka0671
InläggRubrik: Sv: cologne 2.9 V6 turbo questions   cologne 2.9 V6 turbo questions - Sida 3 Icon_minitimetis 23 feb 2010, 20:12
Nice "hole" there Very Happy Whats the setup?
Sida 3 av 4Gå till sida : Föregående  1, 2, 3, 4  Nästa
