| cologne 2.9 V6 turbo questions | |
+7pluto danielrad F20A2-T Henka_ Tehnic Mikael Zozz 11 posters |
danielrad Skogenracing Small
Antal inlägg : 9 Namn : daniel Från : Poland Kör : sierra DOHC & scorpio V6 Registration date : 08-12-30
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 06 jan 2009, 15:36 | |
| i've looked for some polish adverts to search any turbine from a lorry...i've found something like this: http://moto.allegro.pl/item518579040_daf_xf_turbina.htmlit's from daf XF but isn't it TOO LARGE? the price is quite good. i don't know if there is enough space under the hood oh...one more question! where do you get from those large pipes which from you're making inlets to engines? i tried to find something like those you use, but it's quite hard thanks and regards, Daniel | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 06 jan 2009, 19:25 | |
| You need to measure the diameter of the impellers first. Something around 50-55mm inlett and 55-65mm on the turbine.
I quess you mean the pipes betwen turbo/intercooler and manifold/intercooler? we use exhast pipes | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 06 jan 2009, 20:13 | |
| i'm searching for pipes like yours for almost a few hours and i'm unfortunately unable to find it is its diameter 2,5 or 3 inches? will 40mm wastgate be proper or it should be bigger? from which car could i take injectors which will be big enough? thank you for your patience | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 06 jan 2009, 20:24 | |
| Surely you must have a store in Poland that have pipes to build your own exhaust system? I depends but mostly 3 inch but some 2,5 inch
40mm will do but 50mm is better
From a car that have 350cc injectors. BMW M5 E34 for example | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 06 jan 2009, 21:00 | |
| of course, there are stores with steel assortment, but i'm not so sure if they have exactly or very similar pipes..but it shouldn't be big problem i'll find something proper thanks for answers! | |
pluto Skogenracing Small
Antal inlägg : 6 Namn : pluto Från : Estonia Kör : sierra Registration date : 09-02-02
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 02 feb 2009, 16:28 | |
| Hi! I have two engines, one is 2,9 v6 107 KW and the second 2,9 v6 110 KW. Which engine is better to turbo? Excuse me for my english. | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 02 feb 2009, 16:55 | |
| the engine with the lowest compression, i guess that the 107kw have Catalytic converter? It´s usually the engine with the lowest compression | |
Zozz Skogenracing Small
Antal inlägg : 44 Age : 39 Namn : Zoltán Från : Hungary Kör : Scorpio 2.9 12V Ghia, Sierra pinto EFI, Registration date : 08-09-30
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 03 feb 2009, 03:10 | |
| I found a Holset turbo for sale. Here is the link: http://racing-bazar.hu/alkatresz/feltolto/holset_turboI translate the sellers text "I want to sell 1 Holset turbo for truck or what you want, but it's really big! I don't know any specs or data of it but it was surely never used. If you interested call me...." One of the pitcures there is a number on the turbo. Can anyone guess somthing from it? Is it suitable for My 2.9 V6? Excuse me again for my bad english! | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 03 feb 2009, 06:55 | |
| It´s hard to say, there is a number on the blue sign that tells what it is. Then thera is a number in the turbine inlet that says how big the turbon house is
Check these before, and ask him the measure the diameter on the compressor wheel and turbine wheel | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tis 03 feb 2009, 10:56 | |
| Thank you. But I called the seller and I missed it. It was sold. | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tor 12 feb 2009, 12:26 | |
| HI! Is it k27 too large for fitting in your devices? Like i understand is k27 inlet 70 and outlet 60? | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions tor 12 feb 2009, 20:10 | |
| K27 will work. But you have to measure the impellers not the inlett diameter | |
racingbrett Skogenracing Small
Antal inlägg : 2 Age : 43 Namn : brett Från : mathew Kör : dale Registration date : 09-04-19
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 19 apr 2009, 21:08 | |
| All i can say is wow, never knew these motors would take this much power on stock internals. Im currently planning to make my mk1 capri into a daily driver, part of that includes "modernizing" it, the current stock car is a 1.6 xflow automatic ) plan is to fit the 2.8 x-member and fit the 2.9 motor complete with new auto box (any idea how large these are compared to an old borg warner 35?) ... Anyway i was worrying about finding a the cosworth 24v version of this motor for more power while trying to keep costs down, but after reading here and seeing ur vids ill be going with the 12v (nice n cheap) and eventually setting it up with a turbo system. Great site and great work guys keep it up | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 20 apr 2009, 07:07 | |
| The stock engine can easely handle 350hp with good reliability and in a Capri that kind of power i´ts extremly fun The problem will be the automatic, i dont know what will fit or if it will withstand the power and tourqe (500-550nm / 360-400Lbft) | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 17 maj 2009, 20:00 | |
| Mikael What kind of map sensor do you use in the sierra? And what is the fuel consumption of the car at normal driving style (if you can behave yourself with that power under the bonnet ) in city or travelling around 130 kph? Another question: My car earlier was automatic and the engine radiator is remained the automatic version wich have a separated part for cooling the automatic transmission oil. Can I use this part to cool the engine oil before the turbo oil inlet? | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 17 maj 2009, 20:20 | |
| The integrated sensor in the Megasquirt.
Fuel depends on the map, around 1 liter at normal driving.
Use a seperate oilcooler, the water is around 90 degrees so it´s not cooling the oil that much | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions ons 10 jun 2009, 20:30 | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions ons 10 jun 2009, 20:32 | |
| Yes that will be good for a 2.9 engine. You can show us you project in the project forum if you like | |
Tehnic Skogenracing Small
Antal inlägg : 15 Namn : Tehnic Från : EST Kör : SIERRA Registration date : 07-12-17
| Rubrik: Sv: cologne 2.9 V6 turbo questions tor 11 jun 2009, 11:56 | |
| I hava a question. Will someone from sweden make me a plug and play megasquirt ecu for 2.9V6 engine which I simpli can replace with stock ecu when the engine is already turbocharged by myself? If yes, how much will it cost for me? | |
Albis Skogenracing Small
Antal inlägg : 16 Age : 37 Namn : Albis Från : Lithuania Kör : sierra Registration date : 09-06-11
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 14 jun 2009, 17:38 | |
| hi, will it be good to use 2.4 block and 2.9 heads to get les compresion, so i can use more boost. what yuo think about that? | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 14 jun 2009, 17:43 | |
| It´s unnecessary, with good mapping the engine can handle well over 1bar (14psi) with a completely stock engine. you will lose power with less volyme so i don´t like it | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions sön 14 jun 2009, 18:15 | |
| i have a similar turbo, but it is k25 bit smoler will it be good for 2.9? | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 15 jun 2009, 15:15 | |
| - Tehnic skrev:
- I hava a question. Will someone from sweden make me a plug and play megasquirt ecu for 2.9V6 engine which I simpli can replace with stock ecu when the engine is already turbocharged by myself? If yes, how much will it cost for me?
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 15 jun 2009, 19:19 | |
| I dont have time to make one, it´s so simple so you can make it yourself | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions mån 15 jun 2009, 20:56 | |
| Rubrik: Sv: cologne 2.9 V6 turbo questions | |
