 Diesel vs gti kam ?
Diesel vs gti kam ? Empty
InläggRubrik: Diesel vs gti kam ?   Diesel vs gti kam ? Icon_minitimesön 19 nov 2006, 17:50
Är möjlien ingen som har värden på GTI/TD kam ?
richard s
richard s
Antal inlägg : 931
Namn : richard
Från : gävle
Kör : RMK800
InläggRubrik: Sv: Diesel vs gti kam ?   Diesel vs gti kam ? Icon_minitimesön 03 dec 2006, 02:28
Vilken Gti/TD gäller det?
Om det är folka det gäller så hittade jag detta om dom gamla , från Autotech.com :
8V Camshafts - Solid Lifter
From 1975 to the middle of 1980, the specs of the original cam were 0.405 inches lift with 225 degrees duration at .050" check clearance. On later cars, including the Rabbit GTI and Jetta GLI models, the cams were made more docile for pollution control and had a lift of only 0.387 inches, with slightly less duration than earlier.
Hittade TD kam värden , visserligen från en Ford 2.5TD , men ändå :
[code]
Camshaft
mm
Valve timings - inlet opens BTDC
26 ø C/S
Valve timings - exhaust closes ATDC
36 ø C/S
Cam lift (camshaft) - inlet
7.019
Cam lift (camshaft) - exhaust
7.303
Thickness of thrust plate
3.950 - 4.050
Camshaft end float
0.050 - 0.200
Bearing journal ×. front
53.495 - 53.510
Bearing journal ×. centre
53.450 - 53.470
Bearing journal ×. rear
53.480 - 53.500
Bearing journal ×. 1st undersize 0.25 mm
53.245 - 53.260
InläggRubrik: Sv: Diesel vs gti kam ?   Diesel vs gti kam ? Icon_minitimesön 03 dec 2006, 14:29
hmmmm..... Diesel vs gti kam ? 18_crazy
Diesel vs gti kam ?
