| EMU Ecumaster pinto base map | |
Turboescort Skogenracing Small
Antal inlägg : 6 Age : 45 Namn : Shaun Från : Australia Kör : Mk1 escort Mk2 escort Mk2 Cortina Registration date : 17-02-01
| Rubrik: EMU Ecumaster pinto base map ons 01 feb 2017, 12:28 | |
| Does anyone have any maps for the ecumaster for a turbo pinto?
Have just purchased a new ecu and looking for some help to set up some maps.
Thanks, Shaun | |
Antal inlägg : 404 Age : 35 Namn : Bobby Från : Landskrona Kör : Ford Sierra 2.0i Registration date : 14-09-17
| Rubrik: Sv: EMU Ecumaster pinto base map ons 01 feb 2017, 16:53 | |
| think there is some people here that can help you out with that | |
| Rubrik: Sv: EMU Ecumaster pinto base map sön 26 feb 2017, 11:00 | |
| Did you get hold on a basemap? | |
| Rubrik: Sv: EMU Ecumaster pinto base map mån 27 feb 2017, 06:13 | |
| Unfortunately no.
I have tried on the ecumaster forum and their Facebook site with no luck.
Do you have any maps that can help to get me started?
Many thanks.
| Rubrik: Sv: EMU Ecumaster pinto base map mån 27 feb 2017, 06:42 | |
| Yes i have some pinto basemaps. but i need some good detail on your installation, triggers, injectors fuel and so on | |
| Rubrik: Sv: EMU Ecumaster pinto base map mån 27 feb 2017, 22:16 | |
| Michael, you are a legend.
My old turbo engine was cosworth rods and pistons, 550cc injectors, standard hall distributor, batch fire, cosworth t03 turbocharger, 98 octane unleaded petrol. Innovate wideband.
I have not finished the new engine build yet however, I have new rods and pistons for higher compression, some 1000cc injectors, a 36 tooth trigger wheel, larger t3/4 turbo, intend to run e85.
I'm open to new ideas and flexible as to setup depending on what base tune I can get to work with.
The one thing I haven't decided on is came choice. I have about a dozen here ranging from standard to 320+ deg race cams?
What cam/s are you using?
Thanks very much, Shaun. | |
| Rubrik: Sv: EMU Ecumaster pinto base map ons 01 mar 2017, 20:22 | |
| I have a good basemap för 1000cc injectors on e85 but its for stock unopened engine (323whp @ 2bar boost) and GT30 turbo. i think your turbochoice will be a issue, that modell is outdated and higher duration on cam will make the engine a bit unefficient.
change turbo, look for a somewhere around 280 and 11.5-12.0mm lift
I will send you the map if you provide a e-mail | |
| Rubrik: Sv: EMU Ecumaster pinto base map ons 01 mar 2017, 21:39 | |
| Michael, I also have a gt35 sitting on the shelf but thought it was a little large? Might suit the map though.
I will send you a pm with my email.
Thanks again.
| Rubrik: Sv: EMU Ecumaster pinto base map tor 02 mar 2017, 06:50 | |
| - Turboescort skrev:
- Michael, I also have a gt35 sitting on the shelf but thought it was a little large? Might suit the map though.
Thanks again.
GT35 is a bit large compared to the GT30 so i would not choose that turbo | |
| Rubrik: Sv: EMU Ecumaster pinto base map | |
