 sierra dohc 16v + turbo
3 posters
AiToR51
Antal inlägg : 3
Namn : Aitor
Från : Spain
Kör : GZ
Registration date : 16-07-06
sierra dohc 16v + turbo Empty
InläggRubrik: sierra dohc 16v + turbo   sierra dohc 16v + turbo Icon_minitimeons 06 jul 2016, 23:42
Hi,
I've read this forum many times and also saw a lot of videos in youtube. Your cars are lovely
I started turboing my dohc sierra in 2011, after broke 3 dohc 8v engines (std conrods are shit). My record was 255bhp with changed camshafts @ 1bar and MLS headgasket with some durability.
The sierra I'm talking about is the blue 3door in this pic
sierra dohc 16v + turbo IMG_20150613_193949b_zpsceqciuen
After breaking the third engine I swaped to a V6 BOB, I liked it a lot, I was thinking to turbo it also, I tried to legalize the swap but in Spain some things are stupidly difficult. And the lab didn't like a v6 in my sierra (I know.. there were alot of v6 sierras from factory..), I also had a problem with a conrod bearing, so I decided to come back to 2.0, but this time using scorpio N3a engine (2.0 16v)
In this engine I went with maxspeeding rods and C20XE forged pistons. This give me a CR of around 8:1, I don't like this, but couldn't find any cheap option of around 9:1. I could regrind the block but prefered to avoid that.
sierra dohc 16v + turbo IMG_20151211_223955_zpswnlgvm8o
I know my welding is not the best.. Embarassed It was my first big job with my MIG welder
sierra dohc 16v + turbo IMG_20151206_102957_zps6pprxcma
sierra dohc 16v + turbo IMG_20151207_171826_zpse4zhbaor
sierra dohc 16v + turbo IMG_20160313_182903_zpsy76ja0nl
sierra dohc 16v + turbo IMG_20160313_195758_zpsxqrsueml
sierra dohc 16v + turbo IMG_20160313_194155_zpsrbq0xctc
sierra dohc 16v + turbo IMG_20160313_182653_zpsyy3bq1zs
sierra dohc 16v + turbo IMG_20160313_195148_zpsojjzfxpb
sierra dohc 16v + turbo IMG_20160313_153729_zpsasf8nn59
I made a little mistake, read a lot about VGT turbos on petrol engines and end buying a holset he351ve which is supposed to cope well with petrol high EGT's, but i didn't imagine it was as big as it is... I made my own controller, using an Arduino and sending vanes position by CAN commands.. It doesn't spool very well, I don't good boost until I'm over 4500 rpm
sierra dohc 16v + turbo IMG_20150925_203418_zpsiptv64pz
sierra dohc 16v + turbo IMG_20160313_194933_zpsuekirvz3
sierra dohc 16v + turbo IMG_20160313_194622_zpsdterucbf
holset vs t3 from cosworth 2wd:
sierra dohc 16v + turbo IMG_20150925_211157_zpsjbbrlzhg
I will continue on next post
Senast ändrad av AiToR51 den tor 07 jul 2016, 00:25, ändrad totalt 3 gånger
AiToR51
Antal inlägg : 3
Namn : Aitor
Från : Spain
Kör : GZ
InläggRubrik: Sv: sierra dohc 16v + turbo   sierra dohc 16v + turbo Icon_minitimetor 07 jul 2016, 00:10
this was one of the first starts
sierra dohc 16v + turbo IMG_20160508_221326_zps9crwemlb
The ECU I'm using is Megasquirt MS2, but made some testings also with FreeEMS, a good open source project, but it have a lot of work pending. Injectors are from the V6 BOB modded to have more flow. I don't know exactly how much them flows, someting between 500 and 650. I just checked all flowed near the same.
I had some problems with spark wires, so I changed all to VW TFSI COP coils and mod My ECU to suit this. It was a very good mod, I like it.
sierra dohc 16v + turbo IMG_20160624_132126_HHT_zpsbtlgetfs
The engine had done around 1200km but it's not good tuned yet, too much ignition retard, and it's also too much rich on boost. Last week I had a problem with my daily car so I've to get the sierra all week to go to where I live during week (job). I had also water leaks and a problem with my WB EGO, but even with this I wanted to go to a dyno just to see how it was prior good tuning and proper boost.
results were just 236bhp and 315Nm of torque @ 0.8bar of boost . I hope I can improve it a lot. If not I will change the turbo for another smaller.
One of the next mods is installing a supra MK3 LSD diff (3.9:1) in scorpio cosworth rear beam, instead of my cossie 4wd (3.62:1) in std rear beam.
Thierry
Thierry
Antal inlägg : 83
Namn : Thierry
Från : FRANCE
Kör : hondschoote
Registration date : 09-11-22
InläggRubrik: Sv: sierra dohc 16v + turbo   sierra dohc 16v + turbo Icon_minitimefre 08 jul 2016, 23:19
scorpio engine, 2.3 16V ? not 2.0
AiToR51
Antal inlägg : 3
Namn : Aitor
Från : Spain
Kör : GZ
InläggRubrik: Sv: sierra dohc 16v + turbo   sierra dohc 16v + turbo Icon_minitimesön 10 jul 2016, 13:22
yes, in scorpio there are 2.0 8v, 2.0 16v and 2.3 16v. Mine is the 2.0 16v for the simple reason the block is the same in the sierra, so If i broke the engine, I should get easy a replacement. There are not many scorpios 2.0 16v nowadays in spanish junkyards, but 2.3 is near impossible to get one, is really strange. It's easier to get a 2.9 24v. So I decided to go 2.0 16v route for this reason, because if I install a 2.3 and broke it, could be difficult to replace it
InläggRubrik: Sv: sierra dohc 16v + turbo   sierra dohc 16v + turbo Icon_minitimesön 10 jul 2016, 19:56
This is what i like, nice projekt! Smile
» Need help. i want to Turbo my 2.0 DOHC Sierra
» Ford Sierra 2.0 Dohc Turbo CZ
» Ford Sierra 2.0 DOHC Turbo.
» Gr0w - Sierra Dohc Turbo
» Mixx_ - Sierra Dohc turbo
