 Type 9 abuse
rapt
Antal inlägg : 3
Namn : Guy
Från : Israel
Kör : Sierra 2.0i DOHC
Registration date : 13-06-03
Type 9 abuse Empty
InläggRubrik: Type 9 abuse   Type 9 abuse Icon_minitimemån 03 jun 2013, 16:19
Hello Smile i'm new in the forum but i've been viewing it for quite a while.
I had a question regarding the amount of abuse a type 9 can withstand, some said it cannot hold more than 150 bhp, others say it can handle 200 and a bit..
Thanks and i hope to fit in Smile
rapt
Antal inlägg : 3
Namn : Guy
Från : Israel
Type 9 abuse Empty
InläggRubrik: Sv: Type 9 abuse   Type 9 abuse Icon_minitimemån 10 jun 2013, 11:13
No reply? Sad
I have worked on a project (more like my mechanic Smile ) and he mated a Type 9 with a volvo b230 engine
Type 9 abuse 943561_469878936428231_1516653647_n
I wanted to know if i should expect problems since im looking for around 230 bhp, maybe there's something i can do to preserve this gear
Ronny89
Antal inlägg : 19
Namn : Roni
Kör : Capri
Registration date : 12-11-27
Type 9 abuse Empty
InläggRubrik: Sv: Type 9 abuse   Type 9 abuse Icon_minitimetis 06 aug 2013, 07:15
Ford has rated Standard Type 9 to hold 180bhb.
It wont breakdown if you wont abuse it.
By abusing I mean you have narrow tires long ratios.
I have Type 9 HD V6 gearbox its little bit stronger but not much.
I have used it for 10 years. Latest dyno showed me that I have almost 400bhb and 520nm torque.
With my cologne engine. I am also using longest ratio that Atlas axle has 3.09.
Also my tires are street tires witdh of 205mm. I have also LSD so its burning
tires with both wheels. Still I don't race and rarely do hard burnouts so
gearbox still holds the power.
Wider tires and rear axle ratio of 3.44 might brake and gearbox anytime.
Also if the gearbox is gonna hold you need to have it in perfect shape.
It must be quiet, this need very good shimming and all gears and syncros
must be good shape. Clutch cable must be adjusted rightly and all shifts
must be smooth otherwise there will be broken gearbox soon.
Though I am also looking for stronger gearbox but its hard to find one suitable
and easy to fit.
Antal inlägg : 786
Type 9 abuse Empty
InläggRubrik: Sv: Type 9 abuse   Type 9 abuse Icon_minitimefre 20 sep 2013, 17:40
Late answer maybe, I have run with about 300whp, Killed it when I burned some rubber in 2gear on a bumpy road.
rapt
Antal inlägg : 3
Namn : Guy
Från : Israel
Type 9 abuse Empty
InläggRubrik: Sv: Type 9 abuse   Type 9 abuse Icon_minitimeons 15 jul 2015, 22:49
Thanks for the replies! (sorry for the late thanks)
after using the gearbox for over a year with 200+- bhp it's still holding, although I can hear some noises..
Soon ill bump it up a bit (to 250 bhp I hope), but I will decrease the width of my tires to 185/60/15 so I hope it will hold
Thanks again! Smile
Type 9 abuse Empty
Type 9 abuse
» Kändisar som håller på Luleå Hockey
