 Weak Point - OHC Turbo
esracing
esracing
Antal inlägg : 33
Namn : Erik
Från : black forest, germany
Kör : Ford Capri mk1 OHC
Registration date : 12-11-02
InläggRubrik: Weak Point - OHC Turbo   tis 14 maj 2013, 12:34
Hello!
I want to ask what are the weak links of the OHC engine if I Turbocharge them.
I use the 205 Block from Sierra I think with 8,5:1 compression.
If I change the rods to H-rods and use APR Bolts, will the engine last longer
or do I need new pistons aswell?
I try to built a high reving turbo engine and want to use a 300 Degree Cam - Burton BF30
Burton road/rally camshaft .460" lift/300deg duration: SOHC Pinto
Duration 300deg. Timing figures 78/48/48/78. Inlet timing 108deg ATDC. Clearances .008"/.010"
The Turbo I use is a GT2560R Garret.
What is most important?
Oil Cooling ? Turbo Pressure ? Air Cooling ?
I will use a FMIC from Audi 1.8T, pressure not more then 1Bar and
a big Oil Cooler with thermostate.
Is that enough or need I a special Head Gasket, too ?
regards, Erik
InläggRubrik: Sv: Weak Point - OHC Turbo   tis 14 maj 2013, 13:03
The pistons are the weakest point, try to find cosworth pistons and rods and you will have a very strong bottom end.
The headgasket is also weak, but a cosworth grupp A works fine with some 12:9 bolts
You cant build a good working turbo engine with that camshaft and that small turbo, you will have to much exhaust backpressuare.
esracing
esracing
Antal inlägg : 33
Namn : Erik
InläggRubrik: Sv: Weak Point - OHC Turbo   mån 27 maj 2013, 10:59
esracing
esracing
Antal inlägg : 33
Namn : Erik
InläggRubrik: Sv: Weak Point - OHC Turbo   tor 06 jun 2013, 02:50
