| KKK24 for CA18det (help wanted) | |
nesabl Skogenracing Small
Antal inlägg : 17 Age : 28 Namn : Nebojsa Från : Banja Luka Kör : Capri 2800 GT + M62 Registration date : 09-12-08
 | Rubrik: KKK24 for CA18det (help wanted) tis 05 mar 2013, 11:23 | |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) tis 05 mar 2013, 21:21 | |
| anybody, anything ? please
Fiechen Skogenracing Supreme
Antal inlägg : 823 Age : 25 Namn : David Från : Fjärholma Kör : Ford Taunus 2.0T Audi A3 1.8T Audi A4 1.8TSQ Registration date : 10-06-28
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 13:16 | |
| Looks like the same turbo that's found on Audis 2.2 turbo models. It's good for about 250 - 300hp at most  |
Antal inlägg : 1669 Age : 29 Namn : Henrik Från : land Kör : Nissan och Ford Registration date : 06-10-13
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 14:10 | |
| What do you want to do? Stock replacement or for upgrade purpose? It´s kind of hard to tell you if it´s good or not based on what you have tell us  I´m not that into KKK turbos but aren´t the older ones like just the KKK24 just a bit of an old construction? It sure will work if you just want an "easy upgrade" but there are lot better turbos! (Like the Mitsubishi Td04 series or the Garret T28 series, they are often the ones used for replacing the stock T25) |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 15:50 | |
| I am looking to replace blown turbo (tb25) for this kkk24 but tb25 had big lag and this is much bigger exhaust wheel and smaler inlet :/ Part number says that it is from golf 2 1.6 td  good? bad? |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 16:05 | |
| Diesel turbos usually have big exhaust housings for some reason. It will probably work just fine but u will have later spool up due to the bigger exhaust housing |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 16:51 | |
| This turbos exhaust wheel is probably twice size TB25 and intake radius is smaller. Average value of compresor wheel of KkK is bigger than Garrett. Garrett min radius of comp.wheel is 52 or so KKK is about 38 min and max 60 mm LoL Sorry for english I am laughing too :-) |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 22:09 | |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 22:21 | |
| Well I would go for one of the turbos Henrik mentioned and just bolt on, get a little more power aswell. But since your looking to just replace your old one it'll probably do the trick, won't be optimal though.  |
 | Rubrik: Sv: KKK24 for CA18det (help wanted) ons 06 mar 2013, 22:28 | |
| Lol I think the same Also agree with Henrik but it is hard to find that turbos here where I live. I ordered rebuild kit for my TB25 Garrett so until it come from other side of the world I'll try this for sure. It can't be worst then white smoke cloud turbo I'm now using  (god dammit) |
 | Rubrik: Sv: KKK24 for CA18det (help wanted)  | |
