 Mancs - Sierra Estate BOB V6 turbo
Gå till sida : Föregående  1, 2, 3
Mancs
Antal inlägg : 46
Namn : Mancs
Från : Hungary
Kör : Sierra wagon 2.9 24v cosworth
Registration date : 13-02-05
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   mån 03 nov 2014, 19:05
Aah, yes you might want to buy a 6 speed then. Don't know how prices are at you guys though Sad
Ronny89
Antal inlägg : 19
Namn : Roni
Kör : Capri
Registration date : 12-11-27
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   tis 04 nov 2014, 11:08
Mancs skrev:
Yes the 3.09 sounds a little long, but dont forget, that the bimmer tranny is a bit shorter than the usual ford trannys!
BTW here is some motivation, not really a capri fan, but I definitely would love this in my (non existing) garage:
I am using 3.09 rear axle ratio at my Capri atm. It isn't long  in my opinion. If you drive at highway
100km/h rpms are quite high in my case 2500. Could be lowerer. Gearbox atm Type 9 HD soon MT-75 maybe next
summer.
https://onedrive.live.com/redir?resid=D5A3F974DDBF1E4D!1866&authkey=!AIQ3O1g2e64GVl8&ithint=video%2cmp4
I wonder if you can see this... last summer 3.09 + type 9 HD + Quife LSD
Mancs
Antal inlägg : 46
Namn : Mancs
Från : Hungary
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   tis 04 nov 2014, 20:47
2500 isnt that high! Sierras come with 3.6 ; 3.9 and for scorpios 4.2 is also available. I used 3.6 on the sierra and it was long! The 4.2 was a bit to short for everyday use, I could easily drive around in town in fifth gear.
Yep I can see it, some good 'ol tyreshreddin Smile
Mancs
Antal inlägg : 46
Namn : Mancs
Från : Hungary
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   ons 10 dec 2014, 15:36
Car started up finally, after having trouble with my VEMS (bought it used, will never do so again Very Happy ). Coming along nicely.
Mess:
Better:
Final touches:
First start:
https://youtu.be/Ep8G_zHOe9U
Bling bling Very Happy
Headlights in progress:
On a side note, we had a sideproject with friends. A friend of mine bought a scorpio wagon, we put in a BOB with megasquirt, a big lock front suspension, hacked of a lot of wight and go Smile
The car was "built" in 4 days, so obviusly we had to make some compromise, for exmple with the looks of the wiring harness.. Very Happy It works great, everything has relay and fuse, but it just looks sh_t. Well it already done 4 drift days without any problems so its working Smile
Onboard:
https://www.youtube.com/watch?v=2PFMLyro4Mk&feature=youtu.be
The car got a lot of atention, so my friend is planning to make a 4 seater of it with a 4.6 V8, so he can make taxi rides... Smile
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   ons 10 dec 2014, 20:06
Nice Smile
Mancs
Antal inlägg : 46
Namn : Mancs
Från : Hungary
InläggRubrik: Sv: Mancs - Sierra Estate BOB V6 turbo   fre 10 jul 2015, 01:30
Hi guys!
Unfortunately the car is for sale, as I'm having some financial issues. if anyone is intrested, let me know. Its located in Hungary!
Chassis:
Ford sierra wagon
BIG steering lock
Suspension from ford scorpio MK1 (5x112)
Front suspension arms extended and fully poly bushed
Rear suspension stock!
With coilovers (rallydesign)
Fiberglass front hood
With aerocatch hood latches
Plexi sunroof
Rusty parts repaired (exept for cosmetic ones)
Floor mounted pedal box Tilton copy
New chassis harness
Carbon blank lamps (in the front)
Carbon dashboard
Switchpanel next to driver
Fully relayed
Engine + Drivetrain:
2.9 V6 BOB engine, with new timing gear
Modified fuel rail
Skyline injectors
DIY intake plenum
DIY exhaust manifold
76mm exhaust with VBAND fittings, and one muffler at the back
Refurbished turbo (~3582 size)
100mm thick intercooler
50MM WG
50MM BOV
VEMS engine management
New engine harness for vems
Aeromotive A1000 fuel pressure regulator + synthec gauge
19row Oilcooler
Davies Craig EWP150 electric water pump
Rear mounted, HUGE radiator, fully plumped
BOSCH 044 Fuel pump
Plastic racing fuel cell with foam, swirl pot and two fuel pumps (one for the swirl pot, the other one is the BOSCH 044)
BMW 530D transmission welded to the V6 bellhousing, with driveshafts, custom shifter (3cm throw)
APracing clutch with 6 puck sinter
3.6 welded diff with the biggest/strongest halfshafts available for scorpio suspension
Car starts, but its not tuned yet! The whole car needs some finishing to be done (2-3 days of work), it is targeted to run on 100 octane petrol with 0.7 bar (because of the injectors) and at around 350ish HP, and for drifting.
The engine as we know can take a lot more. The car is ready for more power, (BMW transmission, turbo, fuel system etc) appart from the injectors which need replacing for more boost!
If anyone is intrested please let me know! PM or mancs14 (at) gmail (dot)com
Thanks!
Sida 3 av 3Gå till sida : Föregående  1, 2, 3
