andymcf Skogenracing Small
Antal inlägg : 2 Age : 28 Namn : Andrew Från : Northern Ireland Kör : 2.9 v6 Registration date : 12-06-04
 | Rubrik: 2.9 Air Flow meters tor 07 jun 2012, 14:11 | |
| Hello, Basically I am trying to build a 2.9 v6 turbo sierra.
Basically what i have got so far is
sierra shell 2.9 engine with Granada loom complete 2.8 turbo technics car complete 2.9 xr4x4
I have noticed that most of your cars are running without air flow meters. I also have a 2.9 xr4x4 which has air flow meters and it i remove them the car wont start.
I am not even sure if the engine i have requires air flow meters or not as its all parts at the moment. Can you turbo an engine with air flow meters or can you remove them and the car still run. I believe I read somewhere that an engine without air flow meters use lambda sensor or will a Megasquirt ecu resolve this?
Thanks
cosworth team ruse Skogenracing Small
Antal inlägg : 25 Age : 30 Namn : daniel Från : bulgaria Kör : ford sierra 2.0 dohc Registration date : 09-11-24
 | Rubrik: Sv: 2.9 Air Flow meters sön 10 jun 2012, 11:49 | |
| they have the 2.9 engine with lambda sensor and map,your engine is the old one with afm-s.the megasquirt managment have map inside and will do work on your engine |
 | Rubrik: Sv: 2.9 Air Flow meters tis 12 jun 2012, 17:31 | |
| Sorry just to clarify if I install Megasquirt I will not need the air flow meters?
Do you happen to know which is the best version of Megasquirt to install I believe there is MS1, MS2 and MS3?
Antal inlägg : 2023 Age : 37 Namn : Jocke Från : 08-land Kör : Ford P100 Registration date : 06-10-30
 | Rubrik: Sv: 2.9 Air Flow meters ons 13 jun 2012, 14:42 | |
| - andymcf skrev:
- Sorry just to clarify if I install Megasquirt I will not need the air flow meters?
I have an plug n play kit for the ford 60-pin that will work great. Just remove your ECU and plug in the MS2-PnP box right on the harness. Take a house from the intake/plenum and connect it to the built in Map sensor in the MS2 box and just turn the key!  With a single turbo (Holset HX35 or Garrett GT40) and 350cc injectors you can run 1bar of boost on premium fuel and have 323whp (370BHP) and 580BNM or just put on your double turbo kit, some big injectors and tune it yourself. You cant get it any easier.  Price then? £750 with shipping to UK/Irland _________________ // Grey http://www.racemovie.seVisdomsord:
- So thats how easy it is to let people know that you are different, you are not one of them!
- "My definition of insane?
- We are all apprentices in a craft where no one ever becomes a master.
